Date/Time: Sun, 24 Nov 2024 10:32:04 +0000
[User Discussion] - a proposal for CUMULATIVE SUM STUDY indicator
View Count: 182
[2024-06-04 16:47:10] |
User335019 - Posts: 9 |
Hello there, When u make a new update. Do you ever consider to add a new option for CUMULATIVE SUM OF STUDY function. Like ... "Reset/Begin Summation At Time (hourX,minY,secondZ)" . So summation begins at the input "time" which is hourX,minY,secZ. a further addition to this may be; to add a "stop summation time" and/or "stop at session end/trade day end" options Thank you for your attention. Kind Regards Mehmet Alpar |
SierraChart_64_OSlR48RpJy.jpg / V - Attached On 2024-06-04 16:46:59 UTC - Size: 89.51 KB - 66 views |
[2024-06-04 18:16:24] |
emmanuel - Posts: 57 |
The source code for that study comes with Sierra Chart. It's located in C:\SierraChart\ACS_Source\Studies8.cpp, line 983. You can make your own copy and change whatever you want. For example, you can replace the "reset at session start" with a "Reset at" list containing the options: - Session start - Specific time Then add another study input for the time, which would only be used when that option is selected. |
