Date/Time: Wed, 27 Nov 2024 08:31:05 +0000
ed order to trade service
View Count: 1022
[2014-08-21 00:12:36]
User120827 - Posts: 77
Disregard, I found the answer.
thanks
Date Time Of Last Edit: 2014-08-21 01:14:12
[2014-08-21 01:13:39]
Hi
I got it to work properly.
Please disregard this question.
thanks
[2014-08-21 01:16:19]
Your understanding is partially correct.
For a full understanding of how this works, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php#SendOrdersToTradeService
As far as where the code goes, the example should make that clear. 2 of the lines go into the sc.SetDefaults block and the last line goes underneath that block.
[2014-08-21 01:49:44]
ok
thank you for the last sentence about underneath the block.
ACSIL is new to me.
thanks
