Date/Time: Sun, 24 Nov 2024 11:54:50 +0000
Issue with Price Display Format
View Count: 246
[2024-06-04 14:55:28] |
Rnn - Posts: 53 |
Hi, There's an issue with Price Display Format - When using future options I change it to 0.01 so I can view options properly, it sets it to 0.01 but then it flips it back by itself to 0.1 or it stays on 0.01 but when i change the symbol to a different option it sets it back to 0.1 - how do i set it permanently to 0.01? |
[2024-06-04 15:14:08] |
Sierra_Chart Engineering - Posts: 17154 |
You need to set this option to No for the chart: Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-04 15:33:17] |
Rnn - Posts: 53 |
i changed all charts to No but its still flipping it back to 0.1 when I change symbol
[2024-06-05 16:06:14] |
When you change the symbol Auto Set From Data Feed is probably getting re-enabled. So you have to set it back to No again.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-05 16:06:23
[2024-06-05 21:03:00] |
Rnn - Posts: 53 |
yeah, so I need to change it each time I choose a different option, and when its getting re-enabled it also changes some of the other option charts so I always need to change all of the option charts, is there a way to lock it? if not, can u add a feature to choose to lock it so it will stay on 0.01 permanently |
[2024-06-06 20:43:42] |
You need to locate the pattern for the options symbols in the Global Symbol Settings: Global Symbol Settings And change this setting: Auto Set Tick Size and Value Format from Data Feed to be disabled. There may be another way to solve this, refer to this setting: Chart Settings: Do Not Change Symbol Settings for Chart on Symbol Change (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-06 20:44:41
