Date/Time: Sun, 24 Nov 2024 10:38:38 +0000
Issue with time scale not displaying on Sierra Chart
View Count: 151
[2024-06-04 10:03:39] |
User694108 - Posts: 1 |
Dear Sierra Chart Support Team, I am currently experiencing an issue with the Sierra Chartbook where the time scale is not displaying at the bottom of the chart window. I am using the latest version of Sierra Chart, and I have tried various troubleshooting steps, but the problem persists. I have attached a screenshots of my settings, which shows that the relevant options are enabled. Could you kindly assist me in resolving this matter? Thank you in advance for your assistance. Martin Kobosil |
sierrachartbook.png / V - Attached On 2024-06-04 10:01:08 UTC - Size: 180.97 KB - 39 views sierrachatbook1.png / V - Attached On 2024-06-04 10:01:14 UTC - Size: 184.89 KB - 38 views |
[2024-06-04 15:37:23] |
Your Chart Text Color is set to White, so you are not able to see any of the text. Refer to the following: Graphics Settings: Chart Text Also be aware of the difference between chart specific graphics settings and global graphics settings: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
