Date/Time: Sun, 24 Nov 2024 10:29:29 +0000
could not connect with rithmic account
View Count: 324
[2024-06-04 09:58:57]
User473471 - Posts: 7
2024-06-04 09:24:24.049 | Trade activity files set size: 194
2024-06-04 09:24:24.051 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:24:24.057 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2024-06-04 09:24:24.057 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2024-06-04 09:24:24.057 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 34.149.87.45.
2024-06-04 09:24:24.069 | Created the DTC Protocol server.
2024-06-04 09:24:24.069 | DTC Protocol Server listening on port 11099.
2024-06-04 09:24:24.069 | Reading Internal Order ID file.
2024-06-04 09:24:24.079 | Reading Trade Orders file.
2024-06-04 09:24:24.079 | Reading Trade Positions file.
2024-06-04 09:24:24.079 | Reading Trade Account Data files.
2024-06-04 09:24:24.080 | Software version: 2625 64-bit
2024-06-04 09:24:24.080 | Primary Thread ID: 4304
2024-06-04 09:24:24.080 | Usage end date: 2024-06-12
2024-06-04 09:24:24.080 | Enabled for: Advanced Features 2.
2024-06-04 09:24:24.080 | Enabled for: Sierra Chart Historical Data Service.
2024-06-04 09:24:24.080 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-06-04 09:24:24.080 | Enabled for: Delayed Denali Exchange Data Feed.
2024-06-04 09:24:24.080 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-06-04 09:24:24.080 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-06-04 09:24:24.080 | Custom symbol settings values: enabled
2024-06-04 09:24:24.080 | Chart Update Interval: 10
2024-06-04 09:24:24.080 | Intraday Data Storage Time Unit: 0
2024-06-04 09:24:24.080 | Time Zone: +00:00:00 (UTC+00)
2024-06-04 09:24:24.080 | 2024-06-04 09:24:24 Local computer time in UTC
2024-06-04 09:24:24.080 | 2024-06-04 09:24:24 Local computer time in SC Time Zone
2024-06-04 09:24:24.080 | 2024-06-04 09:24:22 Server time in UTC
2024-06-04 09:24:24.080 | Local computer UTC time and Server UTC time difference: 1 seconds.
2024-06-04 09:24:24.080 | Program path: C:\Users\truong\
2024-06-04 09:24:24.080 | Data Files path: C:\Users\truong\Data\
2024-06-04 09:24:24.080 | OS Version Number: 10.0
2024-06-04 09:24:24.080 | Locale Setting: C
2024-06-04 09:24:24.080 | DLLs: UserContributedStudies_64.dll
2024-06-04 09:24:24.080 | Allowed protected custom studies:
2024-06-04 09:24:24.080 | Crash reporter started: true
2024-06-04 09:24:24.080 | Created the DTC Protocol historical data server.
2024-06-04 09:24:24.080 | HD Server Manager | Listening on port 11098.
2024-06-04 09:24:24.080 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2024-06-04 09:24:24.187 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:24:24.187 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:24:24.306 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-06-04 09:24:24.306 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-06-04 09:24:24.428 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2024-06-04 09:24:24.428 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2024-06-04 09:24:24.437 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2024-06-04 09:24:24.437 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed.
2024-06-04 09:24:24.500 | Received 5 login tokens.
2024-06-04 09:24:25.303 | Symbol settings MD5 received. Request ID: 1.
2024-06-04 09:24:25.303 | Symbol settings are up-to-date for rithmic_v2.trading.
2024-06-04 09:24:26.574 | Requested user files to download.
2024-06-04 09:24:28.572 |
2024-06-04 09:24:28.572 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:28.575 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:28.575 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:28.575 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:28.587 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:28.587 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:28.587 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:31.792 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2024-06-04 09:24:31.804 | ESM4.CME 1 Min #3 | Reloading chart.
2024-06-04 09:24:31.815 | NQM4.CME 1 Min #4 | Reloading chart.
2024-06-04 09:24:31.883 | NQM4.CME #2 | Reloading chart.
2024-06-04 09:24:31.889 | NQM4.CME 5 Min #5 | Reloading chart.
2024-06-04 09:24:31.896 | NQM4.CME 10 Min #1 | Reloading chart.
2024-06-04 09:24:31.912 | NQM4.CME 1 Min #6 | Reloading chart.
2024-06-04 09:24:31.934 | NQM4.CME 5 Min #7 | Reloading chart.
2024-06-04 09:24:31.958 | NQM4.CME 10 Min #8 | Reloading chart.
2024-06-04 09:24:31.998 | Using symbol data fast lookup vector
2024-06-04 09:24:31.999 | Starting DelayedDownloadMonitoringTimer
2024-06-04 09:24:31.999 | Starting HDTimeoutTimer
2024-06-04 09:24:31.999 | Added historical Intraday data request for NQM4.CME to the queue.
2024-06-04 09:24:31.999 | Intraday data recording state for symbol NQM4.CME is set to download 'Pending'.
2024-06-04 09:24:31.999 | Triggering next historical data download in queue.
2024-06-04 09:24:32.000 | HD Request # 1 | Downloading Intraday chart data for NQM4.CME to the file NQM4.CME.scid. Service: rithmic.trading
2024-06-04 09:24:32.000 | HD Request # 1 | Download start date-time: 2024-05-31 20:59:59.000000. File last date-time: 2024-05-31 20:59:59.497009
2024-06-04 09:24:32.000 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149. Use encryption.
2024-06-04 09:24:32.006 | Added historical Intraday data request for ESM4.CME to the queue.
2024-06-04 09:24:32.006 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'.
2024-06-04 09:24:32.006 | Triggering next historical data download in queue.
2024-06-04 09:24:32.014 | Socket (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:24:32.014 | Socket (1) | New receive buffer size: 0
2024-06-04 09:24:32.014 | Socket (1) | Connecting to IP: 38.103.112.181.
2024-06-04 09:24:32.072 | NQM4.CME 1 Min #4 | StartDateTimeForLoadingOrderFills: 2024-05-17 16:59:59
2024-06-04 09:24:32.083 | NQM4.CME 1 Min #4 | Chart data loading complete.
2024-06-04 09:24:32.094 | NQM4.CME #2 | StartDateTimeForLoadingOrderFills: 2024-05-17 20:59:59
2024-06-04 09:24:32.097 | NQM4.CME #2 | Chart data loading complete.
2024-06-04 09:24:32.123 | NQM4.CME 5 Min #5 | StartDateTimeForLoadingOrderFills: 2024-05-17 16:59:59
2024-06-04 09:24:32.125 | NQM4.CME 5 Min #5 | Chart data loading complete.
2024-06-04 09:24:32.203 | HD Request # 1 | Sending historical data logon request message.
2024-06-04 09:24:32.588 |
2024-06-04 09:24:32.588 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:32.588 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:32.588 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:32.588 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:32.604 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:32.604 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:32.604 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:32.893 | ESM4.CME 1 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-05-21 08:34:00. Next Bar Date Time: 2024-05-21 08:32:00. Filename: ESM4.CME.scid
2024-06-04 09:24:33.091 | NQM4.CME 10 Min #1 | Chart data loading complete.
2024-06-04 09:24:33.142 | NQM4.CME 5 Min #7 | Chart data loading complete.
2024-06-04 09:24:33.153 | NQM4.CME 1 Min #6 | Chart data loading complete.
2024-06-04 09:24:33.174 | NQM4.CME 10 Min #8 | Chart data loading complete.
2024-06-04 09:24:33.766 | ESM4.CME 1 Min #3 | StartDateTimeForLoadingOrderFills: 2024-05-03 11:28:00
2024-06-04 09:24:33.789 | ESM4.CME 1 Min #3 | Chart data loading complete.
2024-06-04 09:24:36.602 |
2024-06-04 09:24:36.602 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:36.602 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:36.602 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:36.602 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:36.617 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:36.618 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:36.618 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:40.622 |
2024-06-04 09:24:40.623 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:40.623 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:40.623 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:40.623 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:40.639 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:40.639 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:40.639 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:43.454 | Socket (1) | Socket gracefully closed by remote side.
2024-06-04 09:24:43.454 | Socket (1) | CloseSocket call.
2024-06-04 09:24:43.454 | Socket (0) | CloseSocket call.
2024-06-04 09:24:43.454 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-06-04 09:24:43.454 | Socket (1) | Closed.
2024-06-04 09:24:43.454 | HD Request # 1 | Error downloading historical Intraday data for NQM4.CME. The network socket has been closed. Retrying download.
2024-06-04 09:24:43.454 | Added historical Intraday data request for NQM4.CME to the queue.
2024-06-04 09:24:43.454 | Intraday data recording state for symbol NQM4.CME is set to download 'Pending'.
2024-06-04 09:24:43.454 | Triggering next historical data download in queue.
2024-06-04 09:24:43.454 | Historical data download thread signaled to stop.
2024-06-04 09:24:43.454 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQM4.CME
2024-06-04 09:24:43.454 | HD Request # 1 | Completion time: 11s.
2024-06-04 09:24:43.454 | HD Request # 2 | Downloading Intraday chart data for NQM4.CME to the file NQM4.CME.scid. Service: rithmic.trading
2024-06-04 09:24:43.454 | HD Request # 2 | Download start date-time: 2024-05-31 20:59:59.000000. File last date-time: 2024-05-31 20:59:59.497009
2024-06-04 09:24:43.454 | HD Request # 2 | Using server: ds13-2.sierracharts.com port 10150. Use encryption.
2024-06-04 09:24:43.454 | Socket (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:24:43.455 | Socket (1) | New receive buffer size: 0
2024-06-04 09:24:43.455 | Socket (1) | Connecting to IP: 38.142.170.156.
2024-06-04 09:24:43.580 | HD Request # 2 | Sending historical data logon request message.
2024-06-04 09:24:44.631 |
2024-06-04 09:24:44.631 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:44.631 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:44.631 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:44.631 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:44.648 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:44.648 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:44.648 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:48.658 |
2024-06-04 09:24:48.658 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:48.658 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:48.658 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:48.658 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:48.675 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:48.675 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:48.675 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:52.667 |
2024-06-04 09:24:52.667 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:52.667 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:52.667 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:52.667 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:52.683 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:52.683 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:52.683 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:54.730 | Socket (1) | Socket gracefully closed by remote side.
2024-06-04 09:24:54.730 | Socket (1) | CloseSocket call.
2024-06-04 09:24:54.730 | Socket (0) | CloseSocket call.
2024-06-04 09:24:54.730 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-06-04 09:24:54.730 | Socket (1) | Closed.
2024-06-04 09:24:54.730 | HD Request # 2 | Error downloading historical Intraday data for NQM4.CME. The network socket has been closed. Retrying download.
2024-06-04 09:24:54.731 | Added historical Intraday data request for NQM4.CME to the queue.
2024-06-04 09:24:54.731 | Intraday data recording state for symbol NQM4.CME is set to download 'Pending'.
2024-06-04 09:24:54.731 | Triggering next historical data download in queue.
2024-06-04 09:24:54.731 | Historical data download thread signaled to stop.
2024-06-04 09:24:54.731 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQM4.CME
2024-06-04 09:24:54.731 | HD Request # 2 | Completion time: 11s.
2024-06-04 09:24:54.731 | HD Request # 3 | Downloading Intraday chart data for NQM4.CME to the file NQM4.CME.scid. Service: rithmic.trading
2024-06-04 09:24:54.731 | HD Request # 3 | Download start date-time: 2024-05-31 20:59:59.000000. File last date-time: 2024-05-31 20:59:59.497009
2024-06-04 09:24:54.731 | HD Request # 3 | Using server: ds4.sierracharts.com port 10149. Use encryption.
2024-06-04 09:24:54.747 | Socket (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:24:54.747 | Socket (1) | New receive buffer size: 0
2024-06-04 09:24:54.747 | Socket (1) | Connecting to IP: 38.103.112.200.
2024-06-04 09:24:54.942 | HD Request # 3 | Sending historical data logon request message.
2024-06-04 09:24:56.691 |
2024-06-04 09:24:56.691 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:24:56.691 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:24:56.691 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:24:56.691 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:24:56.708 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:24:56.708 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:24:56.708 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:00.716 |
2024-06-04 09:25:00.716 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:00.716 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:00.716 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:00.716 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:00.731 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:00.731 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:00.731 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:04.724 |
2024-06-04 09:25:04.725 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:04.725 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:04.725 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:04.725 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:04.740 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:04.740 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:04.740 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:06.166 | Socket (1) | Socket gracefully closed by remote side.
2024-06-04 09:25:06.166 | Socket (1) | CloseSocket call.
2024-06-04 09:25:06.166 | Socket (0) | CloseSocket call.
2024-06-04 09:25:06.166 | HD Request # 3 | Error downloading historical Intraday data for NQM4.CME. The network socket has been closed. Retrying download.
2024-06-04 09:25:06.166 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-06-04 09:25:06.166 | Socket (1) | Closed.
2024-06-04 09:25:06.166 | Historical data download thread signaled to stop.
2024-06-04 09:25:06.166 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQM4.CME
2024-06-04 09:25:06.166 | HD Request # 3 | Completion time: 12s.
2024-06-04 09:25:06.166 | HD Request # 3 | Intraday data download complete for NQM4.CME. Unique request ID: 1
2024-06-04 09:25:06.166 | Removing historical data download ID 1.
2024-06-04 09:25:06.166 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2024-06-04 09:25:06.166 | Triggering next historical data download in queue.
2024-06-04 09:25:06.166 | HD Request # 4 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: rithmic.trading
2024-06-04 09:25:06.166 | HD Request # 4 | Download start date-time: 2024-05-31 20:59:59.000000. File last date-time: 2024-05-31 20:59:59.052000
2024-06-04 09:25:06.166 | HD Request # 4 | Using server: ds12.sierracharts.com port 10150. Use encryption.
2024-06-04 09:25:06.166 | Socket (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:25:06.166 | Socket (1) | New receive buffer size: 0
2024-06-04 09:25:06.166 | Socket (1) | Connecting to IP: 38.103.112.181.
2024-06-04 09:25:06.335 | HD Request # 4 | Sending historical data logon request message.
2024-06-04 09:25:08.740 |
2024-06-04 09:25:08.740 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:08.740 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:08.740 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:08.740 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:08.757 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:08.757 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:08.757 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:12.757 |
2024-06-04 09:25:12.757 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:12.757 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:12.757 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:12.757 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:12.775 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:12.775 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:12.776 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:16.774 |
2024-06-04 09:25:16.774 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:16.774 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:16.774 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:16.774 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:16.790 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:16.790 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:16.790 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:17.514 | Socket (1) | Socket gracefully closed by remote side.
2024-06-04 09:25:17.514 | Socket (1) | CloseSocket call.
2024-06-04 09:25:17.514 | Socket (0) | CloseSocket call.
2024-06-04 09:25:17.514 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-06-04 09:25:17.514 | Socket (1) | Closed.
2024-06-04 09:25:17.514 | HD Request # 4 | Error downloading historical Intraday data for ESM4.CME. The network socket has been closed. Retrying download.
2024-06-04 09:25:17.514 | Added historical Intraday data request for ESM4.CME to the queue.
2024-06-04 09:25:17.515 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'.
2024-06-04 09:25:17.515 | Triggering next historical data download in queue.
2024-06-04 09:25:17.515 | Historical data download thread signaled to stop.
2024-06-04 09:25:17.515 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM4.CME
2024-06-04 09:25:17.515 | HD Request # 4 | Completion time: 11s.
2024-06-04 09:25:17.515 | HD Request # 5 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: rithmic.trading
2024-06-04 09:25:17.515 | HD Request # 5 | Download start date-time: 2024-05-31 20:59:59.000000. File last date-time: 2024-05-31 20:59:59.052000
2024-06-04 09:25:17.515 | HD Request # 5 | Using server: ds13-2.sierracharts.com port 10149. Use encryption.
2024-06-04 09:25:17.515 | Socket (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:25:17.516 | Socket (1) | New receive buffer size: 0
2024-06-04 09:25:17.516 | Socket (1) | Connecting to IP: 38.142.170.156.
2024-06-04 09:25:17.642 | HD Request # 5 | Sending historical data logon request message.
2024-06-04 09:25:20.788 |
2024-06-04 09:25:20.788 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:20.788 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:20.788 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:20.788 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:20.805 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:20.805 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:20.805 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:24.805 |
2024-06-04 09:25:24.805 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:24.805 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:24.805 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:24.805 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:24.821 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:24.821 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:24.821 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:28.766 | Socket (1) | Socket gracefully closed by remote side.
2024-06-04 09:25:28.766 | Socket (1) | CloseSocket call.
2024-06-04 09:25:28.766 | Socket (0) | CloseSocket call.
2024-06-04 09:25:28.766 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-06-04 09:25:28.766 | Socket (1) | Closed.
2024-06-04 09:25:28.767 | HD Request # 5 | Error downloading historical Intraday data for ESM4.CME. The network socket has been closed. Retrying download.
2024-06-04 09:25:28.767 | Added historical Intraday data request for ESM4.CME to the queue.
2024-06-04 09:25:28.767 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'.
2024-06-04 09:25:28.767 | Triggering next historical data download in queue.
2024-06-04 09:25:28.767 | Historical data download thread signaled to stop.
2024-06-04 09:25:28.767 | HD Request # 5 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM4.CME
2024-06-04 09:25:28.767 | HD Request # 5 | Completion time: 11s.
2024-06-04 09:25:28.767 | HD Request # 6 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: rithmic.trading
2024-06-04 09:25:28.767 | HD Request # 6 | Download start date-time: 2024-05-31 20:59:59.000000. File last date-time: 2024-05-31 20:59:59.052000
2024-06-04 09:25:28.767 | HD Request # 6 | Using server: ds4.sierracharts.com port 10150. Use encryption.
2024-06-04 09:25:28.767 | Socket (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:25:28.767 | Socket (1) | New receive buffer size: 0
2024-06-04 09:25:28.767 | Socket (1) | Connecting to IP: 38.103.112.200.
2024-06-04 09:25:28.818 |
2024-06-04 09:25:28.818 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:28.819 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:28.819 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:28.819 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:28.835 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:28.835 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:28.835 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:28.957 | HD Request # 6 | Sending historical data logon request message.
2024-06-04 09:25:32.838 |
2024-06-04 09:25:32.838 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:32.838 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:32.838 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:32.838 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:32.856 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:32.856 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:32.856 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:36.856 |
2024-06-04 09:25:36.856 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:36.856 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:36.856 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:36.856 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:36.873 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:36.873 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:36.873 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:40.144 | Socket (1) | Socket gracefully closed by remote side.
2024-06-04 09:25:40.145 | Socket (1) | CloseSocket call.
2024-06-04 09:25:40.145 | Socket (0) | CloseSocket call.
2024-06-04 09:25:40.145 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-06-04 09:25:40.145 | Socket (1) | Closed.
2024-06-04 09:25:40.145 | HD Request # 6 | Error downloading historical Intraday data for ESM4.CME. The network socket has been closed. Retrying download.
2024-06-04 09:25:40.145 | Historical data download thread signaled to stop.
2024-06-04 09:25:40.145 | HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM4.CME
2024-06-04 09:25:40.145 | HD Request # 6 | Completion time: 12s.
2024-06-04 09:25:40.145 | HD Request # 6 | Intraday data download complete for ESM4.CME. Unique request ID: 2
2024-06-04 09:25:40.145 | Removing historical data download ID 2.
2024-06-04 09:25:40.145 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2024-06-04 09:25:40.145 | No download requests in the queue to start downloads for.
2024-06-04 09:25:40.869 |
2024-06-04 09:25:40.870 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:40.870 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:40.870 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:40.870 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:40.885 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:40.885 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:40.885 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:44.889 |
2024-06-04 09:25:44.891 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:44.891 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:44.891 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:44.891 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:44.905 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:44.905 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:44.905 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:48.906 |
2024-06-04 09:25:48.907 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:48.907 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:48.907 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:48.907 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:48.923 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:48.923 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:48.923 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:52.912 |
2024-06-04 09:25:52.913 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:52.913 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:52.913 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:52.913 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:52.928 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:52.928 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:52.928 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:56.930 |
2024-06-04 09:25:56.930 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:25:56.930 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:25:56.930 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:25:56.930 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:25:56.946 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:25:56.946 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:25:56.946 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:00.944 |
2024-06-04 09:26:00.944 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:00.944 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:00.944 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:00.944 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:00.960 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:00.960 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:00.960 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:04.962 |
2024-06-04 09:26:04.962 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:04.962 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:04.962 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:04.962 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:04.974 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:04.974 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:04.974 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:08.974 |
2024-06-04 09:26:08.974 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:08.975 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:08.975 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:08.975 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:08.990 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:08.990 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:08.990 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:12.990 |
2024-06-04 09:26:12.990 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:12.990 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:12.990 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:12.990 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:13.008 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:13.008 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:13.008 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:17.005 |
2024-06-04 09:26:17.007 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:17.008 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:17.008 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:17.008 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:17.022 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:17.022 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:17.022 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:21.022 |
2024-06-04 09:26:21.023 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:21.023 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:21.023 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:21.023 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:21.038 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:21.038 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:21.038 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:25.039 |
2024-06-04 09:26:25.039 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:25.039 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:25.039 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:25.039 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:25.055 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:25.055 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:25.055 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:29.052 |
2024-06-04 09:26:29.052 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:29.052 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:29.052 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:29.052 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:29.068 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:29.068 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:29.068 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:33.073 |
2024-06-04 09:26:33.073 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:33.073 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:33.073 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:33.073 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:33.090 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:33.090 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:33.090 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:37.088 |
2024-06-04 09:26:37.089 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:37.089 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:37.089 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:37.089 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:37.105 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:37.106 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:37.106 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:41.107 |
2024-06-04 09:26:41.107 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:41.107 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:41.107 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:41.107 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:41.125 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:41.125 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:41.126 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:45.121 |
2024-06-04 09:26:45.121 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:45.121 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:45.121 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:45.121 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:45.138 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:45.138 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:45.138 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:49.139 |
2024-06-04 09:26:49.139 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:49.139 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:49.139 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:49.139 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:49.157 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:49.157 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:49.157 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:53.152 |
2024-06-04 09:26:53.153 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:53.153 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:53.153 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:53.153 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:53.167 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:53.167 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:53.167 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:57.165 |
2024-06-04 09:26:57.165 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:26:57.165 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:26:57.165 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:26:57.165 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:26:57.181 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:26:57.181 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:26:57.181 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:01.179 |
2024-06-04 09:27:01.179 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:01.179 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:01.179 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:01.179 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:01.195 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:01.195 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:01.195 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:05.198 |
2024-06-04 09:27:05.198 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:05.198 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:05.198 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:05.198 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:05.213 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:05.213 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:05.213 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:09.221 |
2024-06-04 09:27:09.222 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:09.222 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:09.222 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:09.222 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:09.239 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:09.239 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:09.239 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:13.239 |
2024-06-04 09:27:13.239 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:13.239 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:13.239 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:13.239 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:13.258 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:13.258 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:13.258 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:17.256 |
2024-06-04 09:27:17.256 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:17.256 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:17.256 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:17.256 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:17.273 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:17.273 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:17.273 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:21.274 |
2024-06-04 09:27:21.274 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:21.274 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:21.274 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:21.274 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:21.290 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:21.290 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:21.290 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:25.289 |
2024-06-04 09:27:25.289 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:25.289 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:25.289 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:25.289 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:25.306 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:25.307 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:25.307 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:29.302 |
2024-06-04 09:27:29.303 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:29.303 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:29.303 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:29.303 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:29.318 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:29.318 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:29.318 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:33.323 |
2024-06-04 09:27:33.324 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:33.324 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:33.324 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:33.324 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:33.339 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:33.339 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:33.339 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:37.340 |
2024-06-04 09:27:37.340 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:37.341 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:37.341 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:37.341 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:37.357 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:37.357 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:37.357 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:41.357 |
2024-06-04 09:27:41.357 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:41.357 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:41.357 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:41.357 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:41.373 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:41.373 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:41.373 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:45.373 |
2024-06-04 09:27:45.373 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:27:45.373 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:27:45.373 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:27:45.373 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:27:45.389 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:27:45.389 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:27:45.389 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:28:05.383 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:28:05.383 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 0
2024-06-04 09:28:05.383 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:28:05.533 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:28:05.774 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call.
2024-06-04 09:28:05.774 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:28:05.807 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side.
2024-06-04 09:28:05.807 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed.
2024-06-04 09:28:25.375 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:28:25.375 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 0
2024-06-04 09:28:25.375 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:28:25.492 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:28:25.745 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | CloseSocket call.
2024-06-04 09:28:25.745 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:28:25.764 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side.
2024-06-04 09:28:25.764 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Closed.
2024-06-04 09:28:45.379 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:28:45.379 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | New receive buffer size: 0
2024-06-04 09:28:45.379 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:28:45.538 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:28:45.787 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | CloseSocket call.
2024-06-04 09:28:45.787 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:28:45.793 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Socket gracefully closed by remote side.
2024-06-04 09:28:45.794 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Closed.
2024-06-04 09:29:05.613 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:29:05.614 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | New receive buffer size: 0
2024-06-04 09:29:05.614 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:29:05.932 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:29:06.188 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | CloseSocket call.
2024-06-04 09:29:06.188 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:29:06.221 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Socket gracefully closed by remote side.
2024-06-04 09:29:06.222 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Closed.
2024-06-04 09:29:25.373 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:29:25.373 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 0
2024-06-04 09:29:25.373 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:29:25.509 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:29:25.757 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | CloseSocket call.
2024-06-04 09:29:25.757 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:29:25.781 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side.
2024-06-04 09:29:25.781 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Closed.
2024-06-04 09:29:45.376 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:29:45.377 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | New receive buffer size: 0
2024-06-04 09:29:45.377 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:29:45.384 |
2024-06-04 09:29:45.384 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:29:45.384 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:29:45.384 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:29:45.384 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:29:45.405 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:29:45.405 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:29:45.405 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:29:45.486 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:29:45.732 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | CloseSocket call.
2024-06-04 09:29:45.732 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:29:45.747 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Socket gracefully closed by remote side.
2024-06-04 09:29:45.747 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Closed.
2024-06-04 09:30:05.392 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:30:05.392 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | New receive buffer size: 0
2024-06-04 09:30:05.392 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:30:05.555 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:30:05.805 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | CloseSocket call.
2024-06-04 09:30:05.805 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:30:05.813 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Socket gracefully closed by remote side.
2024-06-04 09:30:05.813 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Closed.
2024-06-04 09:30:25.380 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:30:25.380 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | New receive buffer size: 0
2024-06-04 09:30:25.380 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:30:25.588 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:30:25.835 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | CloseSocket call.
2024-06-04 09:30:25.835 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:30:25.880 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Socket gracefully closed by remote side.
2024-06-04 09:30:25.880 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Closed.
2024-06-04 09:30:45.386 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:30:45.386 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | New receive buffer size: 0
2024-06-04 09:30:45.386 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:30:45.575 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:30:45.821 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | CloseSocket call.
2024-06-04 09:30:45.821 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:30:45.854 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Socket gracefully closed by remote side.
2024-06-04 09:30:45.854 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Closed.
2024-06-04 09:31:05.394 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:31:05.394 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | New receive buffer size: 0
2024-06-04 09:31:05.394 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:31:05.513 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:31:05.754 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | CloseSocket call.
2024-06-04 09:31:05.755 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:31:05.775 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Socket gracefully closed by remote side.
2024-06-04 09:31:05.775 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Closed.
2024-06-04 09:31:25.382 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:31:25.383 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | New receive buffer size: 0
2024-06-04 09:31:25.383 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:31:25.548 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:31:25.790 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | CloseSocket call.
2024-06-04 09:31:25.790 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:31:25.817 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Socket gracefully closed by remote side.
2024-06-04 09:31:25.817 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Closed.
2024-06-04 09:31:45.390 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:31:45.390 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | New receive buffer size: 0
2024-06-04 09:31:45.390 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:31:45.404 |
2024-06-04 09:31:45.404 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-04 09:31:45.404 | Rithmic Direct - DTC | Remote address is not set.
2024-06-04 09:31:45.404 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-04 09:31:45.404 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:31:45.419 | DTC Client socket (0) | CloseSocket call.
2024-06-04 09:31:45.419 | Rithmic Direct - DTC | Disconnected.
2024-06-04 09:31:45.419 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-04 09:31:45.520 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:31:45.771 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | CloseSocket call.
2024-06-04 09:31:45.771 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:31:45.777 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Socket gracefully closed by remote side.
2024-06-04 09:31:45.777 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Closed.
2024-06-04 09:32:05.402 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:32:05.402 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | New receive buffer size: 0
2024-06-04 09:32:05.402 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:32:05.572 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:32:05.820 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | CloseSocket call.
2024-06-04 09:32:05.820 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:32:05.836 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Socket gracefully closed by remote side.
2024-06-04 09:32:05.836 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Closed.
2024-06-04 09:32:25.402 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Creating socket. Using TLS 1.2.
2024-06-04 09:32:25.402 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | New receive buffer size: 0
2024-06-04 09:32:25.402 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Connecting to IP: 34.149.87.45.
2024-06-04 09:32:25.584 | Rithmic Direct - DTC | JSON parse error: Invalid value. *
2024-06-04 09:32:25.833 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | CloseSocket call.
2024-06-04 09:32:25.833 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Shutdown started. Waiting for graceful close.
2024-06-04 09:32:25.851 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Socket gracefully closed by remote side.
2024-06-04 09:32:25.851 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Closed.
(Log removed)
Date Time Of Last Edit: 2024-06-04 13:00:54
[2024-06-04 13:00:31]
Sierra_Chart Engineering - Posts: 17154
Refer to:
Connection issues to Rithmic and CQG
