Date/Time: Sun, 24 Nov 2024 11:18:37 +0000
Disconnected
View Count: 206
[2024-06-04 09:45:08] |
User271470 - Posts: 3 |
Hi, I need help. I can t connect to Sierra Chart. It says reconnect wait. I have tried to reconnect it but doesnt work. |
sierra.png / V - Attached On 2024-06-04 09:43:12 UTC - Size: 71.98 KB - 46 views Attachment Deleted. |
[2024-06-04 12:59:26] |
Sierra_Chart Engineering - Posts: 17154 |
Refer to: Connection issues to Rithmic and CQG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-04 12:59:33
