Date/Time: Sun, 24 Nov 2024 11:11:58 +0000
Connecting Problems
View Count: 283
[2024-06-04 05:47:13]
nicktrader - Posts: 709
I have connection problems this morning. I-net is stable.
When I open the platform, I get data, but then yellow and connecting and connect wait
[2024-06-04 05:51:55]
I suspect it is due to the broker “AMP”. When I open the platform with the Denali data feed, everything is green...
[2024-06-04 05:54:55]
At the moment the “CQG” connection is running again and shows green...
[2024-06-04 06:11:28]
Same "CQG" connection problems again... yellow... "Denali" green...
[2024-06-04 07:28:54]
Sierra_Chart Engineering - Posts: 17154
So to confirm you are just having issues connecting to CQG?
[2024-06-04 08:00:04]
Only when "CQG". At the moment everything is fine and works proper.
[2024-06-04 10:30:30]
I just openend my platform and same problem with the "CQG" connection...
I ask "AMP" and I got this message: "You would need to clarify directly with Sierra the connectivity issue . We confirm your account is enabled for LIVE data on our end."
If I start the platform with "Denali" connection still there.
[2024-06-04 10:39:59]
"CQG" is now green... after 5min or more.
I saved the message log...
I tested it again: Start 12:43 connection: yellow
12:47 connection: green
I saved the message log again...
Date Time Of Last Edit: 2024-06-04 10:50:05
[2024-06-04 13:00:15]
Refer to:
Connection issues to Rithmic and CQG
[2024-06-05 03:32:58]
Thank you very much. I trade EUREX and unfortunately you have not yet implemented the fact that Teton can also be used there.
