Date/Time: Thu, 26 Nov 2026 21:06:02 +0000
Unspecified array unallocated message.
View Count: 1576
| [2014-08-20 20:58:53] |
| User66972 - Posts: 3 |
Hello we are receiving this message when running a custom study that we have created. Software version: 1173 | 2014-08-20 13:51:28 Enabled for: Advanced Features. | 2014-08-20 13:51:28 Enabled for: Advanced Features 2. | 2014-08-20 13:51:28 Enabled for: Sierra Chart Historical Data Service. | 2014-08-20 13:51:28 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-20 13:51:28 Active service: SC Forex Data (FXCM) | 2014-08-20 13:51:28 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-20 13:51:28 2014-08-20 13:51:28 Local computer clock time | 2014-08-20 13:51:28 2014-08-20 20:51:28 GMT time | 2014-08-20 13:51:28 2014-08-20 13:51:28 Time zone adjusted time | 2014-08-20 13:51:28 Time difference to server time: 4 seconds. | 2014-08-20 13:51:28 Program path: C:\SC 2\ | 2014-08-20 13:51:28 Data Files path: C:\SC 2\Data\ | 2014-08-20 13:51:28 OS Version Number: 6.1 | 2014-08-20 13:51:28 Checking for new symbol settings for fxcm | 2014-08-20 13:51:28 AsyncHTTP2 socket (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-20 13:51:28 AsyncHTTP2 socket (1212) | Connected. | 2014-08-20 13:51:28 Requesting symbol settings for fxcm. Overwrite = on. | 2014-08-20 13:51:28 Symbol settings received. | 2014-08-20 13:51:30 Processed received symbol settings | 2014-08-20 13:51:30 SC Forex Data (FXCM) | Connecting to the server ds3.sierracharts.com. Port 443 | 2014-08-20 13:51:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-08-20 13:51:33 Socket (1732) | Connected. | 2014-08-20 13:51:33 SC Forex Data (FXCM) | Connected to server. | 2014-08-20 13:51:33 SC Forex Data (FXCM) | Sending logon request message. | 2014-08-20 13:51:33 SC Forex Data (FXCM) | Server Info - Server Name: . | 2014-08-20 13:51:33 SC Forex Data (FXCM) | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-20 13:51:33 SC Forex Data (FXCM) | Successfully connected. | 2014-08-20 13:51:33 AsyncHTTP2 socket (1212) | Closed. No error. | 2014-08-20 13:51:40 AsyncHTTP2 socket (1212) | Shutdown and closed. | 2014-08-20 13:51:40 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPUSD. ID: 1 | 2014-08-20 13:51:43 Intraday data recording state for symbol GBPUSD is set to pending. | 2014-08-20 13:51:43 HD Request # 2 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2014-08-20 13:51:43 HD Request # 2 | Download start Date-Time: 2014-08-19 15:08:03.0 | 2014-08-20 13:51:43 HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2014-08-20 13:51:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-08-20 13:51:43 Socket (1780) | Connected. | 2014-08-20 13:51:43 HD Request # 2 | Sending historical data logon request message. | 2014-08-20 13:51:43 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-08-19 15:08:03. Record interval: 1. Symbol: GBPUSD | 2014-08-20 13:51:44 HD Request # 2 | Decompressing data. | 2014-08-20 13:51:44 HD Request # 2 | Receiving Intraday data for GBPUSD starting at 2014-08-19 15:08:03 | 2014-08-20 13:51:44 HD Request # 2 | Timestamp of first Intraday data file record written: 2014-08-19 15:08:03 | 2014-08-20 13:51:44 Socket (1780) | Shutdown and closed. | 2014-08-20 13:51:45 The network socket for historical data has been closed. | 2014-08-20 13:51:45 HD Request # 2 | Received 30262 records from 2014-08-19 15:08:03 to 2014-08-20 13:51:39 (22.7 hours) and wrote 30262 records for GBPUSD | 2014-08-20 13:51:45 HD Request # 2 | Intraday download COMPLETE for GBPUSD. Completion time: 2s | 2014-08-20 13:51:45 Real-time Intraday chart data file updates started for GBPUSD | 2014-08-20 13:51:45 : Array is unallocated. | 2014-08-20 13:51:56 : Array is unallocated. | 2014-08-20 13:51:56 : Array is unallocated. | 2014-08-20 13:51:56 : Array is unallocated. | 2014-08-20 13:51:56 : Array is unallocated. | 2014-08-20 13:52:01 : Array is unallocated. | 2014-08-20 13:52:01 It will repeat this message until it reaches a limit. |
| [2014-08-20 21:06:19] |
I forgot to mention that the custom study works otherwise, just that array unallocated message repeats in the log until it's reached the limit. Thank you. |
| [2014-08-20 21:12:49] |
It is necessary for us to get a simple code example from you that we can test which demonstrates the problem so we can isolate the source of the problem.
| [2014-08-21 16:54:15] |
Is there a private email that we can send the code to instead of posting it on the forum?
| [2014-08-21 17:34:21] |
Yes you can use support AT Sierra Chart.com, but we need a simple as possible example.
