Date/Time: Sun, 24 Nov 2024 11:00:01 +0000
Cannot Connect to Rithmic - Server list empty
View Count: 470
[2024-06-04 03:25:28]
User509187 - Posts: 22
Have looked through the support boards and done everything I'm supposed to do - followed the steps to connect, selected Rithmic and filled out the appropriate info, clicked ok, waited 5 minutes, waited 1 HR, turned off firewall, restart computer etc etc.
Still only shows the originally selected service setting, which is the wrong one, and if I click to change it - always empty.
Please help.
Thank you
[2024-06-04 03:26:48]
Remote address is not set is the error in the message panel.
Also see JSON parse error: invalid value.
[2024-06-04 03:28:21]
If I download an entirely new Sierra software the servers show up - I just don't want to re do the whole setup and add the chartbook again.
[2024-06-04 07:21:14]
ClydeXSi - Posts: 1
Update Sierra, it worked for me.
[2024-06-04 13:17:00]
Sierra_Chart Engineering - Posts: 17154
Refer to this thread:
Connection issues to Rithmic and CQG
[2024-06-04 13:29:32]
ScalpHard - Posts: 1
Same issue here. I updated Sierra to current version. Issue is now resolved. Thank you
[2024-06-05 08:43:31]
tptelly - Posts: 2
Had the same issue - updated and works now.
