Date/Time: Sun, 24 Nov 2024 11:00:49 +0000
i need help with chartbook setting on forex pairs Pls
View Count: 136
[2024-06-03 20:54:12]
crixten26 - Posts: 1
I need help with chartbook on forex pairs Footprint setting... i got a chartbook and i have been unable to get the right settings for it on forex pair cause its was used on Future pairs before....I will be so grateful if you guys can help i am new on sierra
[2024-06-03 21:01:06]
There is no particular difference between futures and forex in terms of the Numbers Bars. It is just a matter of having things setup as you want to view them.
First, refer to the following for how to scale a Numbers Bars chart:
Numbers Bars: Scaling a Numbers Bars Chart
And then you also need to keep in mind that there is a tradeoff that has to be made for Numbers Bars in terms of being able to view the data and the amount of data you can view.
If you still need help, then we need to know exactly what it is that you are seeing and what the problem is. Also please give us an image by following these instructions:
