Date/Time: Sun, 24 Nov 2024 11:03:16 +0000
Connect to trade service issues
View Count: 217
[2024-06-03 20:18:56] |
User109490 - Posts: 11 |
Good afternoon, Sc has been unable to connect to my Rithmic (Apex)accounts all (local) evening, for reason of 'remote adress not set'. No clue as to what caused this, yesterday no problems and last week's trading gave no issues either. Upon starting I did not get any farther than friday close, a third (or fourth) attempt (closing and openening Sc, then restarting the computer) got me to today 11:16 and then 15:00 (CT) worth of data, but no new data printing. I run CQG (AMP) in another instance of Sc, all was fine there. Could this be a Denali issue? Charts all have the [M] showing Denali overrides. Not this time. I copy and paste the message log here and hope you can identify the problem and solve it c.q. help me in solving it. Thank you. Lex. 2024-06-03 21:47:58.012 | Trade activity files set size: 210 2024-06-03 21:47:58.023 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:47:58.028 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-06-03 21:47:58.028 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-06-03 21:47:58.028 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 34.149.87.45. 2024-06-03 21:47:58.062 | Created the DTC Protocol server. 2024-06-03 21:47:58.063 | DTC Protocol Server listening on port 11099. 2024-06-03 21:47:58.064 | DTC Protocol Server listening on port 11100. 2024-06-03 21:47:58.064 | Reading Internal Order ID file. 2024-06-03 21:47:58.148 | Reading Trade Orders file. 2024-06-03 21:47:58.149 | Reading Trade Positions file. 2024-06-03 21:47:58.149 | Reading Trade Account Data files. 2024-06-03 21:47:58.156 | UDPListener (1712). Port 22904 | Listening on UDP port 22904. 2024-06-03 21:47:58.156 | Software version: 2580 64-bit 2024-06-03 21:47:58.156 | Primary Thread ID: 10272 2024-06-03 21:47:58.156 | Usage end date: 2024-09-05 2024-06-03 21:47:58.156 | Enabled for: Advanced Features 2. 2024-06-03 21:47:58.156 | Enabled for: Sierra Chart Historical Data Service. 2024-06-03 21:47:58.156 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-06-03 21:47:58.156 | Enabled for: Delayed Denali Exchange Data Feed. 2024-06-03 21:47:58.156 | Enabled for exchange2: CME 2024-06-03 21:47:58.156 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-06-03 21:47:58.156 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-06-03 21:47:58.156 | Custom symbol settings values: enabled 2024-06-03 21:47:58.156 | Chart Update Interval: 20 2024-06-03 21:47:58.156 | Intraday Data Storage Time Unit: 0 2024-06-03 21:47:58.156 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-06-03 21:47:58.156 | 2024-06-03 19:47:58 Local computer time in UTC 2024-06-03 21:47:58.156 | 2024-06-03 21:47:58 Local computer time in SC Time Zone 2024-06-03 21:47:58.156 | 2024-06-03 19:47:57 Server time in UTC 2024-06-03 21:47:58.156 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-06-03 21:47:58.156 | Program path: C:\Sierra2\ 2024-06-03 21:47:58.156 | Data Files path: C:\Sierra2\Data\ 2024-06-03 21:47:58.156 | OS Version Number: 10.0 2024-06-03 21:47:58.156 | Locale Setting: C 2024-06-03 21:47:58.156 | DLLs: UserContributedStudies_64.dll 2024-06-03 21:47:58.156 | Allowed protected custom studies: 2024-06-03 21:47:58.156 | Crash reporter started: true 2024-06-03 21:47:58.156 | 2024-06-03 21:47:58.179 | Created the DTC Protocol historical data server. 2024-06-03 21:47:58.180 | HD Server Manager | Listening on port 11098. 2024-06-03 21:47:58.180 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-06-03 21:47:58.286 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:47:58.304 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:47:58.436 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-06-03 21:47:58.436 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-06-03 21:47:58.558 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-06-03 21:47:58.558 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. 2024-06-03 21:47:58.566 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2024-06-03 21:47:58.566 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. 2024-06-03 21:47:58.731 | Received 5 login tokens. 2024-06-03 21:47:59.535 | Symbol settings MD5 received. Request ID: 1. 2024-06-03 21:47:59.535 | Symbol settings are up-to-date for rithmic_v2.trading. 2024-06-03 21:48:00.664 | Requested user files to download. 2024-06-03 21:48:02.669 | 2024-06-03 21:48:02.669 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:02.672 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:02.672 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:02.672 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:02.685 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:02.685 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:02.685 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:06.680 | 2024-06-03 21:48:06.680 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:06.680 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:06.680 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:06.680 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:06.696 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:06.696 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:06.696 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:10.706 | 2024-06-03 21:48:10.707 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:10.707 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:10.707 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:10.707 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:10.722 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:10.722 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:10.722 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:14.717 | 2024-06-03 21:48:14.718 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:14.718 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:14.718 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:14.718 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:14.733 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:14.733 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:14.733 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:18.728 | 2024-06-03 21:48:18.728 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:18.728 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:18.728 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:18.728 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:18.744 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:18.744 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:18.744 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:19.232 | ESM4.CME [CBV] 20000 Trades #8 | Reloading chart. 2024-06-03 21:48:19.264 | NQM4.CME [CV] 30 Min #16 | Reloading chart. 2024-06-03 21:48:19.273 | Starting DelayedDownloadMonitoringTimer 2024-06-03 21:48:19.273 | Starting HDTimeoutTimer 2024-06-03 21:48:19.273 | Added historical Intraday data request for NQU3.CME to the queue. 2024-06-03 21:48:19.273 | Triggering next historical data download in queue. 2024-06-03 21:48:19.419 | NQM4.CME [CV] 30 Min #16 | Waiting for historical downloads to complete with the IDs: 1, 2024-06-03 21:48:19.431 | NQM4.CME [CBV] 9000 Trades #19 | Reloading chart. 2024-06-03 21:48:19.462 | ESM4.CME [CV] 3.25 Range #10 | Reloading chart. 2024-06-03 21:48:19.496 | NQM4.CME [CV] Daily #11 | Reloading chart. 2024-06-03 21:48:19.637 | NQM4.CME 8.25 Range #9 | Reloading chart. 2024-06-03 21:48:19.653 | NQM4.CME [CV] 30 Min #12 | Reloading chart. 2024-06-03 21:48:19.730 | ESM4.CME [CV] 1 Min #18 | Reloading chart. 2024-06-03 21:48:19.919 | ESM4.CME [CV] 3 Min #7 | Reloading chart. 2024-06-03 21:48:20.010 | NQM4.CME 2250 Trades #2 | Reloading chart. 2024-06-03 21:48:20.112 | ESM4.CME [CV] 2500 Trades #5 | Reloading chart. 2024-06-03 21:48:20.280 | NQM4.CME [CV] #3 | Reloading chart. 2024-06-03 21:48:20.382 | NQM4.CME [CV] 5 Min #13 | Reloading chart. 2024-06-03 21:48:20.531 | NQM4.CME [CV] 1 Min #4 | Reloading chart. 2024-06-03 21:48:20.744 | NQM4.CME [CV] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 1, 2024-06-03 21:48:20.831 | NQM4.CME [CV] 2 Min #1 | Reloading chart. 2024-06-03 21:48:21.085 | NQM4.CME [CV] 5 Min #6 | Reloading chart. 2024-06-03 21:48:21.281 | ESM4.CME #15 | Reloading chart. 2024-06-03 21:48:21.302 | ESM4.CME [CV] 60 Min #17 | Reloading chart. 2024-06-03 21:48:23.222 | TICK-NYSE 1 Min #14 | Reloading chart. 2024-06-03 21:48:23.761 | Mapping NQU3.CME to NQU23. Service code: cme 2024-06-03 21:48:23.761 | Using symbol data fast lookup vector 2024-06-03 21:48:23.761 | HD Request # 1 | Downloading Intraday chart data for NQU3.CME to the file NQU3.CME.scid. Service: cme 2024-06-03 21:48:23.762 | HD Request # 1 | Download start date-time: 2023-07-27 19:08:57.000000. File last date-time: 2023-07-27 19:08:57.642020 2024-06-03 21:48:23.762 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2024-06-03 21:48:26.604 | NQM4.CME 8.25 Range #9 | StartDateTimeForLoadingOrderFills: 2024-05-20 18:40:41 2024-06-03 21:48:28.477 | ESM4.CME [CV] 3.25 Range #10 | StartDateTimeForLoadingOrderFills: 2024-05-20 18:40:42 2024-06-03 21:48:29.628 | Mapping ESM4.CME to ESM24. Service code: cme 2024-06-03 21:48:29.628 | Added historical Intraday data request for ESM4.CME to the queue. 2024-06-03 21:48:29.628 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'. 2024-06-03 21:48:29.642 | Triggering next historical data download in queue. 2024-06-03 21:48:30.009 | Mapping NQM4.CME to NQM24. Service code: cme 2024-06-03 21:48:30.009 | Added historical Intraday data request for NQM4.CME to the queue. 2024-06-03 21:48:30.009 | Intraday data recording state for symbol NQM4.CME is set to download 'Pending'. 2024-06-03 21:48:30.009 | Triggering next historical data download in queue. 2024-06-03 21:48:30.519 | Socket (1) | Creating socket. 2024-06-03 21:48:30.519 | Socket (1) | New receive buffer size: 0 2024-06-03 21:48:30.519 | Socket (1) | Connecting to IP: 38.103.112.187. 2024-06-03 21:48:31.646 | NQM4.CME [CV] 2 Min #1 | StartDateTimeForLoadingOrderFills: 2024-05-06 00:00:00 2024-06-03 21:48:32.047 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-06-03 21:48:32.047 | HD Request # 1 | Sending historical data logon request message. 2024-06-03 21:48:32.048 | NQM4.CME [CV] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2024-05-06 00:00:00 2024-06-03 21:48:32.748 | HD Request # 1 | Requesting Intraday data. Start date-time: 2023-07-27 19:08:57. Record interval: 0. Symbol: NQU23 2024-06-03 21:48:33.270 | HD Request # 1 | Decompressing data. 2024-06-03 21:48:33.289 | HD Request # 1 | Receiving Intraday data for NQU3.CME starting at 2023-07-27 19:08:57.018000 2024-06-03 21:48:34.141 | HD Request # 1 | Timestamp of first Intraday data file record written: 2023-07-27 19:08:57.642021. 2024-06-03 21:48:34.526 | ESM4.CME [CV] 3 Min #7 | StartDateTimeForLoadingOrderFills: 2024-05-06 00:00:00 2024-06-03 21:48:35.006 | 2024-06-03 21:48:35.130 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:35.130 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:35.130 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:35.130 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:35.254 | Added historical Intraday data request for TICK-NYSE to the queue. 2024-06-03 21:48:35.254 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2024-06-03 21:48:35.255 | Triggering next historical data download in queue. 2024-06-03 21:48:35.316 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:35.316 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:35.316 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:37.276 | NQM4.CME [CBV][M] 9000 Trades #19 | StartDateTimeForLoadingOrderFills: 2024-04-23 15:30:00 2024-06-03 21:48:39.311 | 2024-06-03 21:48:39.311 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:39.311 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:39.311 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:39.311 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:39.331 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:39.331 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:39.331 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:39.431 | NQM4.CME[M] 2250 Trades #2 | StartDateTimeForLoadingOrderFills: 2024-02-26 01:01:10 2024-06-03 21:48:42.282 | ESM4.CME [CV][M] 2500 Trades #5 | StartDateTimeForLoadingOrderFills: 2024-04-22 22:15:00 2024-06-03 21:48:43.332 | 2024-06-03 21:48:43.332 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:43.333 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:43.333 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:43.333 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:43.353 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:43.353 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:43.353 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:44.181 | ESM4.CME [CBV][M] 20000 Trades #8 | StartDateTimeForLoadingOrderFills: 2024-04-23 15:30:00 2024-06-03 21:48:47.366 | 2024-06-03 21:48:47.366 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:47.366 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:47.366 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:47.366 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:47.386 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:47.386 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:47.386 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:51.386 | 2024-06-03 21:48:51.386 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:51.386 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:51.386 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:51.386 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:51.406 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:51.407 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:51.407 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:55.416 | 2024-06-03 21:48:55.416 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:55.416 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:55.416 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:55.416 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:55.436 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:55.436 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:55.436 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:59.448 | 2024-06-03 21:48:59.449 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:48:59.449 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:48:59.449 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:48:59.449 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:48:59.464 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:48:59.464 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:48:59.464 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:02.252 | ESM4.CME [CV][M] 60 Min #17 | StartDateTimeForLoadingOrderFills: 2023-11-27 00:30:00 2024-06-03 21:49:03.496 | 2024-06-03 21:49:03.496 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:03.496 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:03.496 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:03.496 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:03.512 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:03.512 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:03.512 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:07.538 | 2024-06-03 21:49:07.538 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:07.538 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:07.538 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:07.538 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:07.554 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:07.554 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:07.554 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:08.381 | NQM4.CME [CV][M] 5 Min #13 | StartDateTimeForLoadingOrderFills: 2023-11-27 07:10:00 2024-06-03 21:49:09.870 | NQM4.CME [CV][M] 30 Min #12 | StartDateTimeForLoadingOrderFills: 2023-11-27 01:00:00 2024-06-03 21:49:11.548 | 2024-06-03 21:49:11.548 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:11.548 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:11.548 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:11.548 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:11.564 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:11.564 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:11.564 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:15.559 | 2024-06-03 21:49:15.559 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:15.559 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:15.559 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:15.559 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:15.574 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:15.574 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:15.574 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:19.585 | 2024-06-03 21:49:19.585 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:19.585 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:19.585 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:19.585 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:19.600 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:19.600 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:19.600 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:23.611 | 2024-06-03 21:49:23.611 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:23.611 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:23.611 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:23.611 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:23.626 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:23.626 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:23.627 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:27.622 | 2024-06-03 21:49:27.622 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:27.622 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:27.622 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:27.622 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:27.642 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:27.642 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:27.642 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:31.638 | 2024-06-03 21:49:31.638 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:31.638 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:31.638 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:31.638 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:31.658 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:31.658 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:31.658 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:35.650 | 2024-06-03 21:49:35.650 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:35.650 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:35.650 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:35.650 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:35.670 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:35.670 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:35.670 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:39.681 | 2024-06-03 21:49:39.681 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:39.682 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:39.682 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:39.682 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:39.702 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:39.702 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:39.702 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:43.711 | 2024-06-03 21:49:43.711 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:43.711 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:43.711 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:43.711 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:43.731 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:43.731 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:43.731 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:47.730 | 2024-06-03 21:49:47.730 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:47.730 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:47.730 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:47.730 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:47.750 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:47.750 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:47.750 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:51.745 | 2024-06-03 21:49:51.745 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:51.745 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:51.745 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:51.745 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:51.765 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:51.765 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:51.765 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:55.759 | 2024-06-03 21:49:55.760 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:49:55.760 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:49:55.760 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:49:55.760 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:55.780 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:49:55.780 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:49:55.780 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:49:59.227 | ESM4.CME [CV][M] 1 Min #18 | StartDateTimeForLoadingOrderFills: 2023-05-29 02:01:00 2024-06-03 21:50:01.437 | 2024-06-03 21:50:01.437 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:01.437 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:01.437 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:01.437 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:01.447 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:01.447 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:01.447 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:05.449 | 2024-06-03 21:50:05.450 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:05.450 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:05.450 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:05.450 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:05.465 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:05.465 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:05.465 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:09.476 | 2024-06-03 21:50:09.476 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:09.476 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:09.476 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:09.476 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:09.491 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:09.491 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:09.491 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:13.502 | 2024-06-03 21:50:13.502 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:13.502 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:13.502 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:13.502 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:13.518 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:13.518 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:13.518 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:17.528 | 2024-06-03 21:50:17.528 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:17.528 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:17.528 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:17.528 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:17.544 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:17.544 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:17.544 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:21.539 | 2024-06-03 21:50:21.539 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:21.539 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:21.539 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:21.539 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:21.555 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:21.555 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:21.555 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:25.588 | 2024-06-03 21:50:25.588 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:25.588 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:25.588 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:25.588 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:25.603 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:25.603 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:25.603 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:29.630 | 2024-06-03 21:50:29.630 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:29.630 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:29.630 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:29.630 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:29.645 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:29.645 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:29.645 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:33.641 | 2024-06-03 21:50:33.641 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:33.641 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:33.641 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:33.641 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:33.656 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:33.656 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:33.656 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:37.651 | 2024-06-03 21:50:37.651 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:37.651 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:37.651 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:37.651 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:37.667 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:37.667 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:37.667 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:41.678 | 2024-06-03 21:50:41.678 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:41.678 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:41.678 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:41.678 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:41.693 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:41.693 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:41.693 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:45.704 | 2024-06-03 21:50:45.704 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:45.704 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:45.704 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:45.704 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:45.720 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:45.720 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:45.720 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:49.715 | 2024-06-03 21:50:49.715 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:49.715 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:49.715 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:49.715 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:49.731 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:49.731 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:49.731 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:53.726 | 2024-06-03 21:50:53.726 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:53.726 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:53.726 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:53.726 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:53.741 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:53.741 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:53.741 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:57.752 | 2024-06-03 21:50:57.752 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:50:57.752 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:50:57.752 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:50:57.752 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:50:57.774 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:50:57.774 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:50:57.774 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:01.785 | 2024-06-03 21:51:01.785 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:01.785 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:01.785 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:01.785 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:01.801 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:01.801 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:01.801 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:05.796 | 2024-06-03 21:51:05.796 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:05.796 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:05.796 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:05.796 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:05.812 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:05.812 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:05.812 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:09.807 | 2024-06-03 21:51:09.807 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:09.807 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:09.807 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:09.807 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:09.822 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:09.822 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:09.822 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:13.833 | 2024-06-03 21:51:13.833 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:13.833 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:13.833 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:13.833 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:13.849 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:13.849 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:13.849 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:15.498 | Socket (1) | CloseSocket call. 2024-06-03 21:51:15.498 | Historical data download thread signaled to stop. 2024-06-03 21:51:15.498 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:51:15.499 | HD Request # 1 | Received 18287772 Intraday data records from 2023-07-27 19:08:57.018000 to 2023-09-15 15:29:58.203005 (49.8 days. Delay: 262.3 days) and wrote 18287730 records for NQU3.CME 2024-06-03 21:51:15.500 | HD Request # 1 | Completion time: 2m 52s. 2024-06-03 21:51:15.500 | HD Request # 1 | Intraday data download complete for NQU3.CME. Unique request ID: 1 2024-06-03 21:51:15.500 | Removing historical data download ID 1. 2024-06-03 21:51:15.500 | Real-time Intraday chart data file updates started for NQU3.CME 2024-06-03 21:51:15.500 | Intraday chart data file opened for NQU3.CME 2024-06-03 21:51:15.500 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-06-03 21:51:15.500 | 2024-06-03 21:51:15.500 | Triggering next historical data download in queue. 2024-06-03 21:51:15.500 | Historical data for NQU3.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-06-03 21:51:15.500 | HD Request # 2 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: cme 2024-06-03 21:51:15.501 | HD Request # 2 | Download start date-time: 2024-06-03 18:40:42.000000. File last date-time: 2024-06-03 18:40:42.662000 2024-06-03 21:51:15.501 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149 2024-06-03 21:51:15.513 | Socket (2) | Creating socket. 2024-06-03 21:51:15.513 | Socket (2) | New receive buffer size: 0 2024-06-03 21:51:15.513 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-06-03 21:51:15.524 | NQM4.CME [CV] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-06-03 21:51:15.526 | NQM4.CME [CV] 1 Min #4 | Reloading chart. 2024-06-03 21:51:15.566 | NQM4.CME [CV] 30 Min #16 | Download is complete for all contract months in chart. Proceeding with data load. 2024-06-03 21:51:15.589 | NQM4.CME [CV] 30 Min #16 | Reloading chart. 2024-06-03 21:51:15.612 | Socket (1) | Socket gracefully closed by remote side. 2024-06-03 21:51:15.612 | Socket (1) | Closed. 2024-06-03 21:51:15.663 | NQM4.CME [CV] 1 Min #4 | Reloading chart. 2024-06-03 21:51:15.740 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-06-03 21:51:15.740 | HD Request # 2 | Sending historical data logon request message. 2024-06-03 21:51:15.818 | NQM4.CME [CV] 30 Min #16 | Reloading chart. 2024-06-03 21:51:16.148 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-06-03 18:40:42. Record interval: 0. Symbol: ESM24 2024-06-03 21:51:16.255 | HD Request # 2 | Decompressing data. 2024-06-03 21:51:16.266 | HD Request # 2 | Receiving Intraday data for ESM4.CME starting at 2024-06-03 18:40:42.005000 2024-06-03 21:51:16.606 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-06-03 18:40:42.767000. 2024-06-03 21:51:17.859 | 2024-06-03 21:51:17.859 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:17.859 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:17.859 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:17.859 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:17.961 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:17.961 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:17.961 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:20.627 | Socket (2) | CloseSocket call. 2024-06-03 21:51:20.627 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-03 21:51:20.627 | Historical data download thread signaled to stop. 2024-06-03 21:51:20.628 | HD Request # 2 | Received 342133 Intraday data records from 2024-06-03 18:40:42.005000 to 2024-06-03 21:51:20.414001 (3.2 hours. Delay: 0.2 seconds) and wrote 342079 records for ESM4.CME 2024-06-03 21:51:20.628 | HD Request # 2 | Completion time: 5s. 2024-06-03 21:51:20.628 | HD Request # 2 | Intraday data download complete for ESM4.CME. Unique request ID: 2 2024-06-03 21:51:20.628 | Removing historical data download ID 2. 2024-06-03 21:51:20.628 | Real-time Intraday chart data file updates started for ESM4.CME 2024-06-03 21:51:20.628 | Intraday chart data file opened for ESM4.CME 2024-06-03 21:51:20.628 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-06-03 21:51:20.628 | 2024-06-03 21:51:20.628 | Triggering next historical data download in queue. 2024-06-03 21:51:20.628 | Historical data for ESM4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-06-03 21:51:20.628 | HD Request # 3 | Downloading Intraday chart data for NQM4.CME to the file NQM4.CME.scid. Service: cme 2024-06-03 21:51:20.629 | HD Request # 3 | Download start date-time: 2024-06-03 18:40:41.000000. File last date-time: 2024-06-03 18:40:41.237000 2024-06-03 21:51:20.629 | HD Request # 3 | Using server: ds27.sierracharts.com port 10150 2024-06-03 21:51:20.644 | Socket (1) | Creating socket. 2024-06-03 21:51:20.644 | Socket (1) | New receive buffer size: 0 2024-06-03 21:51:20.644 | Socket (1) | Connecting to IP: 208.185.224.131. 2024-06-03 21:51:20.735 | Socket (2) | Socket gracefully closed by remote side. 2024-06-03 21:51:20.735 | Socket (2) | Closed. 2024-06-03 21:51:20.840 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-06-03 21:51:20.840 | HD Request # 3 | Sending historical data logon request message. 2024-06-03 21:51:21.209 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-06-03 18:40:41. Record interval: 0. Symbol: NQM24 2024-06-03 21:51:21.305 | HD Request # 3 | Decompressing data. 2024-06-03 21:51:21.315 | HD Request # 3 | Receiving Intraday data for NQM4.CME starting at 2024-06-03 18:40:41.017000 2024-06-03 21:51:21.657 | HD Request # 3 | Timestamp of first Intraday data file record written: 2024-06-03 18:40:41.267000. 2024-06-03 21:51:22.129 | 2024-06-03 21:51:22.129 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:22.129 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:22.129 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:22.129 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:22.320 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:22.320 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:22.320 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:22.749 | Socket (1) | CloseSocket call. 2024-06-03 21:51:22.749 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:51:22.775 | Historical data download thread signaled to stop. 2024-06-03 21:51:22.775 | HD Request # 3 | Received 165573 Intraday data records from 2024-06-03 18:40:41.017000 to 2024-06-03 21:51:21.578000 (3.2 hours. Delay: 1.2 seconds) and wrote 165562 records for NQM4.CME 2024-06-03 21:51:22.775 | HD Request # 3 | Completion time: 2s. 2024-06-03 21:51:22.775 | HD Request # 3 | Intraday data download complete for NQM4.CME. Unique request ID: 3 2024-06-03 21:51:22.775 | Removing historical data download ID 3. 2024-06-03 21:51:22.775 | Real-time Intraday chart data file updates started for NQM4.CME 2024-06-03 21:51:22.775 | Intraday chart data file opened for NQM4.CME 2024-06-03 21:51:22.775 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-06-03 21:51:22.775 | 2024-06-03 21:51:22.775 | Triggering next historical data download in queue. 2024-06-03 21:51:22.775 | Historical data for NQM4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-06-03 21:51:22.775 | HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2024-06-03 21:51:22.776 | HD Request # 4 | Download start date-time: 2024-06-03 18:40:42.000000. File last date-time: 2024-06-03 18:40:42.000000 2024-06-03 21:51:22.776 | HD Request # 4 | Using server: ds12.sierracharts.com port 10149 2024-06-03 21:51:22.792 | Socket (2) | Creating socket. 2024-06-03 21:51:22.792 | Socket (2) | New receive buffer size: 0 2024-06-03 21:51:22.792 | Socket (2) | Connecting to IP: 38.103.112.181. 2024-06-03 21:51:22.845 | Socket (1) | Socket gracefully closed by remote side. 2024-06-03 21:51:22.845 | Socket (1) | Closed. 2024-06-03 21:51:23.046 | HD Request # 4 | Setting DTC encoding to Binary VLS 2024-06-03 21:51:23.046 | HD Request # 4 | Sending historical data logon request message. 2024-06-03 21:51:23.408 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-06-03 18:40:42. Record interval: 0. Symbol: TICK-NYSE 2024-06-03 21:51:23.542 | HD Request # 4 | Decompressing data. 2024-06-03 21:51:23.567 | HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2024-06-03 18:40:42.000000 2024-06-03 21:51:24.164 | Socket (2) | CloseSocket call. 2024-06-03 21:51:24.164 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-06-03 21:51:24.164 | Historical data download thread signaled to stop. 2024-06-03 21:51:24.164 | HD Request # 4 | Timestamp of first Intraday data file record written: 2024-06-03 18:40:43.000000. 2024-06-03 21:51:24.164 | HD Request # 4 | Received 11434 Intraday data records from 2024-06-03 18:40:42.000000 to 2024-06-03 21:51:22.000000 (3.2 hours. Delay: 2.2 seconds) and wrote 11433 records for TICK-NYSE 2024-06-03 21:51:24.164 | HD Request # 4 | Completion time: 2s. 2024-06-03 21:51:24.164 | HD Request # 4 | Intraday data download complete for TICK-NYSE. Unique request ID: 4 2024-06-03 21:51:24.164 | Removing historical data download ID 4. 2024-06-03 21:51:24.164 | Real-time Intraday chart data file updates started for TICK-NYSE 2024-06-03 21:51:24.164 | Intraday chart data file opened for TICK-NYSE 2024-06-03 21:51:24.164 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-06-03 21:51:24.164 | 2024-06-03 21:51:24.164 | No download requests in the queue to start downloads for. 2024-06-03 21:51:24.164 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-06-03 21:51:24.292 | Socket (2) | Socket gracefully closed by remote side. 2024-06-03 21:51:24.292 | Socket (2) | Closed. 2024-06-03 21:51:26.312 | 2024-06-03 21:51:26.313 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:26.313 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:26.313 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:26.313 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:26.328 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:26.328 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:26.328 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:30.323 | 2024-06-03 21:51:30.323 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:30.323 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:30.323 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:30.323 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:30.338 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:30.338 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:30.338 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:34.371 | 2024-06-03 21:51:34.371 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:51:34.371 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:51:34.371 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:51:34.371 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:34.387 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:51:34.387 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:51:34.387 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:51:54.371 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:51:54.371 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 0 2024-06-03 21:51:54.371 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:51:54.440 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:51:54.686 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. 2024-06-03 21:51:54.686 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:51:54.695 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. 2024-06-03 21:51:54.695 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. 2024-06-03 21:52:14.384 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:52:14.384 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 0 2024-06-03 21:52:14.384 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:52:14.444 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:52:14.685 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | CloseSocket call. 2024-06-03 21:52:14.685 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:52:14.693 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. 2024-06-03 21:52:14.693 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Closed. 2024-06-03 21:52:25.020 | NQM4.CME [CV][M] 1 Min #4 | StartDateTimeForLoadingOrderFills: 2023-06-05 00:00:00 2024-06-03 21:52:34.387 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:52:34.388 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | New receive buffer size: 0 2024-06-03 21:52:34.388 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:52:34.454 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:52:34.687 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | CloseSocket call. 2024-06-03 21:52:34.687 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:52:34.697 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. 2024-06-03 21:52:34.697 | HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Closed. 2024-06-03 21:52:54.419 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:52:54.419 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | New receive buffer size: 0 2024-06-03 21:52:54.419 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:52:54.489 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:52:54.741 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | CloseSocket call. 2024-06-03 21:52:54.741 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:52:54.751 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. 2024-06-03 21:52:54.751 | HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Closed. 2024-06-03 21:53:14.432 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:53:14.433 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 0 2024-06-03 21:53:14.433 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:53:14.500 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:53:14.748 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | CloseSocket call. 2024-06-03 21:53:14.748 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:53:14.757 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side. 2024-06-03 21:53:14.757 | HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Closed. 2024-06-03 21:53:34.385 | 2024-06-03 21:53:34.385 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:53:34.385 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:53:34.385 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:53:34.385 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:53:34.400 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:53:34.400 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:53:34.400 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:53:54.412 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:53:54.412 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | New receive buffer size: 0 2024-06-03 21:53:54.412 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:53:54.473 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:53:54.712 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | CloseSocket call. 2024-06-03 21:53:54.712 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:53:54.721 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Socket gracefully closed by remote side. 2024-06-03 21:53:54.721 | HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Closed. 2024-06-03 21:54:14.404 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:54:14.404 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | New receive buffer size: 0 2024-06-03 21:54:14.404 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:54:14.471 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:54:14.735 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | CloseSocket call. 2024-06-03 21:54:14.735 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:54:14.744 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Socket gracefully closed by remote side. 2024-06-03 21:54:14.744 | HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Closed. 2024-06-03 21:54:34.412 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:54:34.412 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | New receive buffer size: 0 2024-06-03 21:54:34.412 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:54:34.481 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:54:34.750 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | CloseSocket call. 2024-06-03 21:54:34.750 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:54:34.762 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Socket gracefully closed by remote side. 2024-06-03 21:54:34.762 | HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Closed. 2024-06-03 21:54:54.404 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:54:54.404 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | New receive buffer size: 0 2024-06-03 21:54:54.404 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:54:54.473 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:54:54.735 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | CloseSocket call. 2024-06-03 21:54:54.735 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:54:54.744 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Socket gracefully closed by remote side. 2024-06-03 21:54:54.744 | HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Closed. 2024-06-03 21:55:14.420 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:55:14.420 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | New receive buffer size: 0 2024-06-03 21:55:14.420 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:55:14.487 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:55:14.720 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | CloseSocket call. 2024-06-03 21:55:14.720 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:55:14.728 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Socket gracefully closed by remote side. 2024-06-03 21:55:14.728 | HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (1) | Closed. 2024-06-03 21:55:34.411 | 2024-06-03 21:55:34.411 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:55:34.411 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:55:34.411 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:55:34.411 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:55:34.426 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:55:34.426 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:55:34.426 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:55:54.412 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:55:54.413 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | New receive buffer size: 0 2024-06-03 21:55:54.413 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:55:54.490 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:55:54.728 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | CloseSocket call. 2024-06-03 21:55:54.728 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:55:54.738 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Socket gracefully closed by remote side. 2024-06-03 21:55:54.738 | HTTPS connection ID:12 to www.rithmic.com:443 for request ID:12 (1) | Closed. 2024-06-03 21:56:14.420 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:56:14.420 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | New receive buffer size: 0 2024-06-03 21:56:14.420 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:56:14.488 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:56:14.751 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | CloseSocket call. 2024-06-03 21:56:14.751 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:56:14.760 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Socket gracefully closed by remote side. 2024-06-03 21:56:14.761 | HTTPS connection ID:13 to www.rithmic.com:443 for request ID:13 (1) | Closed. 2024-06-03 21:56:34.420 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:56:34.420 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | New receive buffer size: 0 2024-06-03 21:56:34.420 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:56:34.524 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:56:34.774 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | CloseSocket call. 2024-06-03 21:56:34.774 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:56:34.783 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Socket gracefully closed by remote side. 2024-06-03 21:56:34.783 | HTTPS connection ID:14 to www.rithmic.com:443 for request ID:14 (1) | Closed. 2024-06-03 21:56:54.428 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:56:54.428 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | New receive buffer size: 0 2024-06-03 21:56:54.428 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:56:54.490 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:56:54.728 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | CloseSocket call. 2024-06-03 21:56:54.728 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:56:54.736 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Socket gracefully closed by remote side. 2024-06-03 21:56:54.736 | HTTPS connection ID:15 to www.rithmic.com:443 for request ID:15 (1) | Closed. 2024-06-03 21:57:14.428 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:57:14.428 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | New receive buffer size: 0 2024-06-03 21:57:14.428 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:57:14.494 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:57:14.728 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | CloseSocket call. 2024-06-03 21:57:14.728 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:57:14.737 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | Socket gracefully closed by remote side. 2024-06-03 21:57:14.737 | HTTPS connection ID:16 to www.rithmic.com:443 for request ID:16 (1) | Closed. 2024-06-03 21:57:34.434 | 2024-06-03 21:57:34.434 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:57:34.434 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:57:34.434 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:57:34.434 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:57:34.450 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:57:34.450 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:57:34.450 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:57:54.451 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:57:54.451 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | New receive buffer size: 0 2024-06-03 21:57:54.452 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:57:54.516 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:57:54.751 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | CloseSocket call. 2024-06-03 21:57:54.751 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:57:54.762 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | Socket gracefully closed by remote side. 2024-06-03 21:57:54.762 | HTTPS connection ID:17 to www.rithmic.com:443 for request ID:17 (1) | Closed. 2024-06-03 21:58:14.459 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:58:14.459 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | New receive buffer size: 0 2024-06-03 21:58:14.459 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:58:14.520 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:58:14.774 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | CloseSocket call. 2024-06-03 21:58:14.774 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:58:14.783 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | Socket gracefully closed by remote side. 2024-06-03 21:58:14.783 | HTTPS connection ID:18 to www.rithmic.com:443 for request ID:18 (1) | Closed. 2024-06-03 21:58:34.455 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:58:34.455 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | New receive buffer size: 0 2024-06-03 21:58:34.455 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:58:34.519 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:58:34.770 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | CloseSocket call. 2024-06-03 21:58:34.770 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:58:34.779 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | Socket gracefully closed by remote side. 2024-06-03 21:58:34.779 | HTTPS connection ID:19 to www.rithmic.com:443 for request ID:19 (1) | Closed. 2024-06-03 21:58:54.461 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:58:54.462 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | New receive buffer size: 0 2024-06-03 21:58:54.462 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:58:54.526 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:58:54.777 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | CloseSocket call. 2024-06-03 21:58:54.777 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:58:54.787 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | Socket gracefully closed by remote side. 2024-06-03 21:58:54.787 | HTTPS connection ID:20 to www.rithmic.com:443 for request ID:20 (1) | Closed. 2024-06-03 21:59:14.461 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:59:14.461 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | New receive buffer size: 0 2024-06-03 21:59:14.461 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:59:14.524 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:59:14.777 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | CloseSocket call. 2024-06-03 21:59:14.777 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:59:14.786 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | Socket gracefully closed by remote side. 2024-06-03 21:59:14.786 | HTTPS connection ID:21 to www.rithmic.com:443 for request ID:21 (1) | Closed. 2024-06-03 21:59:34.446 | 2024-06-03 21:59:34.446 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 21:59:34.446 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 21:59:34.446 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 21:59:34.446 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:59:34.468 | DTC Client socket (0) | CloseSocket call. 2024-06-03 21:59:34.468 | Rithmic Direct - DTC | Disconnected. 2024-06-03 21:59:34.468 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 21:59:54.451 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | Creating socket. Using TLS 1.2. 2024-06-03 21:59:54.451 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | New receive buffer size: 0 2024-06-03 21:59:54.451 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 21:59:54.520 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 21:59:54.782 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | CloseSocket call. 2024-06-03 21:59:54.782 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 21:59:54.792 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | Socket gracefully closed by remote side. 2024-06-03 21:59:54.792 | HTTPS connection ID:22 to www.rithmic.com:443 for request ID:22 (1) | Closed. 2024-06-03 22:00:14.452 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:00:14.452 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | New receive buffer size: 0 2024-06-03 22:00:14.452 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:00:14.515 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:00:14.752 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | CloseSocket call. 2024-06-03 22:00:14.752 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:00:14.764 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | Socket gracefully closed by remote side. 2024-06-03 22:00:14.764 | HTTPS connection ID:23 to www.rithmic.com:443 for request ID:23 (1) | Closed. 2024-06-03 22:00:34.459 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:00:34.460 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | New receive buffer size: 0 2024-06-03 22:00:34.460 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:00:34.524 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:00:34.759 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | CloseSocket call. 2024-06-03 22:00:34.759 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:00:34.769 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | Socket gracefully closed by remote side. 2024-06-03 22:00:34.769 | HTTPS connection ID:24 to www.rithmic.com:443 for request ID:24 (1) | Closed. 2024-06-03 22:00:54.460 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:00:54.461 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | New receive buffer size: 0 2024-06-03 22:00:54.461 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:00:54.527 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:00:54.782 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | CloseSocket call. 2024-06-03 22:00:54.783 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:00:54.792 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | Socket gracefully closed by remote side. 2024-06-03 22:00:54.792 | HTTPS connection ID:25 to www.rithmic.com:443 for request ID:25 (1) | Closed. 2024-06-03 22:01:14.452 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:01:14.453 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | New receive buffer size: 0 2024-06-03 22:01:14.453 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:01:14.517 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:01:14.768 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | CloseSocket call. 2024-06-03 22:01:14.768 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:01:14.777 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | Socket gracefully closed by remote side. 2024-06-03 22:01:14.777 | HTTPS connection ID:26 to www.rithmic.com:443 for request ID:26 (1) | Closed. 2024-06-03 22:01:34.454 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:01:34.454 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | New receive buffer size: 0 2024-06-03 22:01:34.454 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:01:34.468 | 2024-06-03 22:01:34.468 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 22:01:34.468 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 22:01:34.468 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 22:01:34.468 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:01:34.491 | DTC Client socket (0) | CloseSocket call. 2024-06-03 22:01:34.491 | Rithmic Direct - DTC | Disconnected. 2024-06-03 22:01:34.491 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:01:34.518 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:01:34.754 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | CloseSocket call. 2024-06-03 22:01:34.754 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:01:34.762 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | Socket gracefully closed by remote side. 2024-06-03 22:01:34.762 | HTTPS connection ID:27 to www.rithmic.com:443 for request ID:27 (1) | Closed. 2024-06-03 22:01:54.476 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:01:54.477 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | New receive buffer size: 0 2024-06-03 22:01:54.477 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:01:54.553 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:01:54.792 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | CloseSocket call. 2024-06-03 22:01:54.792 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:01:54.801 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | Socket gracefully closed by remote side. 2024-06-03 22:01:54.802 | HTTPS connection ID:28 to www.rithmic.com:443 for request ID:28 (1) | Closed. 2024-06-03 22:02:14.462 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:02:14.462 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | New receive buffer size: 0 2024-06-03 22:02:14.462 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:02:14.531 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:02:14.778 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | CloseSocket call. 2024-06-03 22:02:14.778 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:02:14.787 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | Socket gracefully closed by remote side. 2024-06-03 22:02:14.787 | HTTPS connection ID:29 to www.rithmic.com:443 for request ID:29 (1) | Closed. 2024-06-03 22:02:34.485 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:02:34.485 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | New receive buffer size: 0 2024-06-03 22:02:34.485 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:02:34.549 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:02:34.785 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | CloseSocket call. 2024-06-03 22:02:34.785 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:02:34.794 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | Socket gracefully closed by remote side. 2024-06-03 22:02:34.794 | HTTPS connection ID:30 to www.rithmic.com:443 for request ID:30 (1) | Closed. 2024-06-03 22:02:54.509 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:02:54.509 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | New receive buffer size: 0 2024-06-03 22:02:54.509 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:02:54.577 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:02:54.824 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | CloseSocket call. 2024-06-03 22:02:54.824 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:02:54.833 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | Socket gracefully closed by remote side. 2024-06-03 22:02:54.834 | HTTPS connection ID:31 to www.rithmic.com:443 for request ID:31 (1) | Closed. 2024-06-03 22:03:14.525 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:03:14.525 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | New receive buffer size: 0 2024-06-03 22:03:14.525 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:03:14.586 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:03:14.825 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | CloseSocket call. 2024-06-03 22:03:14.825 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:03:14.837 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | Socket gracefully closed by remote side. 2024-06-03 22:03:14.837 | HTTPS connection ID:32 to www.rithmic.com:443 for request ID:32 (1) | Closed. 2024-06-03 22:03:34.478 | 2024-06-03 22:03:34.479 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 22:03:34.479 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 22:03:34.479 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 22:03:34.479 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:03:34.494 | DTC Client socket (0) | CloseSocket call. 2024-06-03 22:03:34.494 | Rithmic Direct - DTC | Disconnected. 2024-06-03 22:03:34.494 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:03:54.502 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:03:54.502 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | New receive buffer size: 0 2024-06-03 22:03:54.502 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:03:54.566 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:03:54.818 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | CloseSocket call. 2024-06-03 22:03:54.818 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:03:54.828 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | Socket gracefully closed by remote side. 2024-06-03 22:03:54.828 | HTTPS connection ID:33 to www.rithmic.com:443 for request ID:33 (1) | Closed. 2024-06-03 22:04:14.503 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:04:14.503 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | New receive buffer size: 0 2024-06-03 22:04:14.504 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:04:14.567 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:04:14.825 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | CloseSocket call. 2024-06-03 22:04:14.825 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:04:14.834 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | Socket gracefully closed by remote side. 2024-06-03 22:04:14.834 | HTTPS connection ID:34 to www.rithmic.com:443 for request ID:34 (1) | Closed. 2024-06-03 22:04:34.506 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:04:34.506 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | New receive buffer size: 0 2024-06-03 22:04:34.506 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:04:34.574 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:04:34.811 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | CloseSocket call. 2024-06-03 22:04:34.811 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:04:34.819 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | Socket gracefully closed by remote side. 2024-06-03 22:04:34.820 | HTTPS connection ID:35 to www.rithmic.com:443 for request ID:35 (1) | Closed. 2024-06-03 22:04:54.496 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:04:54.497 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | New receive buffer size: 0 2024-06-03 22:04:54.497 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:04:54.567 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:04:54.828 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | CloseSocket call. 2024-06-03 22:04:54.828 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:04:54.836 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | Socket gracefully closed by remote side. 2024-06-03 22:04:54.836 | HTTPS connection ID:36 to www.rithmic.com:443 for request ID:36 (1) | Closed. 2024-06-03 22:05:14.498 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:05:14.498 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | New receive buffer size: 0 2024-06-03 22:05:14.498 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:05:14.566 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:05:14.813 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | CloseSocket call. 2024-06-03 22:05:14.813 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:05:14.822 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | Socket gracefully closed by remote side. 2024-06-03 22:05:14.822 | HTTPS connection ID:37 to www.rithmic.com:443 for request ID:37 (1) | Closed. 2024-06-03 22:05:34.504 | 2024-06-03 22:05:34.505 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 22:05:34.505 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 22:05:34.505 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 22:05:34.505 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:05:34.520 | DTC Client socket (0) | CloseSocket call. 2024-06-03 22:05:34.520 | Rithmic Direct - DTC | Disconnected. 2024-06-03 22:05:34.520 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:05:54.506 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:05:54.506 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | New receive buffer size: 0 2024-06-03 22:05:54.506 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:05:54.567 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:05:54.822 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | CloseSocket call. 2024-06-03 22:05:54.822 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:05:54.830 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | Socket gracefully closed by remote side. 2024-06-03 22:05:54.830 | HTTPS connection ID:38 to www.rithmic.com:443 for request ID:38 (1) | Closed. 2024-06-03 22:06:14.514 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:06:14.514 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | New receive buffer size: 0 2024-06-03 22:06:14.514 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:06:14.591 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:06:14.845 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | CloseSocket call. 2024-06-03 22:06:14.845 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:06:14.853 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | Socket gracefully closed by remote side. 2024-06-03 22:06:14.854 | HTTPS connection ID:39 to www.rithmic.com:443 for request ID:39 (1) | Closed. 2024-06-03 22:06:34.530 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:06:34.530 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | New receive buffer size: 0 2024-06-03 22:06:34.530 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:06:34.593 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:06:34.830 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | CloseSocket call. 2024-06-03 22:06:34.830 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:06:34.838 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | Socket gracefully closed by remote side. 2024-06-03 22:06:34.838 | HTTPS connection ID:40 to www.rithmic.com:443 for request ID:40 (1) | Closed. 2024-06-03 22:06:54.554 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:06:54.554 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | New receive buffer size: 0 2024-06-03 22:06:54.554 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:06:54.619 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:06:54.853 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | CloseSocket call. 2024-06-03 22:06:54.854 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:06:54.863 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | Socket gracefully closed by remote side. 2024-06-03 22:06:54.863 | HTTPS connection ID:41 to www.rithmic.com:443 for request ID:41 (1) | Closed. 2024-06-03 22:07:14.556 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:07:14.556 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | New receive buffer size: 0 2024-06-03 22:07:14.556 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:07:14.618 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:07:14.876 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | CloseSocket call. 2024-06-03 22:07:14.876 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:07:14.886 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | Socket gracefully closed by remote side. 2024-06-03 22:07:14.886 | HTTPS connection ID:42 to www.rithmic.com:443 for request ID:42 (1) | Closed. 2024-06-03 22:07:34.530 | 2024-06-03 22:07:34.530 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 22:07:34.530 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 22:07:34.530 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 22:07:34.530 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:07:34.545 | DTC Client socket (0) | CloseSocket call. 2024-06-03 22:07:34.545 | Rithmic Direct - DTC | Disconnected. 2024-06-03 22:07:34.545 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:07:54.547 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:07:54.548 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | New receive buffer size: 0 2024-06-03 22:07:54.548 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:07:54.610 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:07:54.847 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | CloseSocket call. 2024-06-03 22:07:54.847 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:07:54.856 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | Socket gracefully closed by remote side. 2024-06-03 22:07:54.856 | HTTPS connection ID:43 to www.rithmic.com:443 for request ID:43 (1) | Closed. 2024-06-03 22:08:14.555 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:08:14.555 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | New receive buffer size: 0 2024-06-03 22:08:14.555 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:08:14.621 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:08:14.870 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | CloseSocket call. 2024-06-03 22:08:14.870 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:08:14.880 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | Socket gracefully closed by remote side. 2024-06-03 22:08:14.880 | HTTPS connection ID:44 to www.rithmic.com:443 for request ID:44 (1) | Closed. 2024-06-03 22:08:34.564 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:08:34.564 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | New receive buffer size: 0 2024-06-03 22:08:34.564 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:08:34.630 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:08:34.880 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | CloseSocket call. 2024-06-03 22:08:34.880 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:08:34.889 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | Socket gracefully closed by remote side. 2024-06-03 22:08:34.889 | HTTPS connection ID:45 to www.rithmic.com:443 for request ID:45 (1) | Closed. 2024-06-03 22:08:54.565 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:08:54.566 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | New receive buffer size: 0 2024-06-03 22:08:54.566 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:08:54.633 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:08:54.919 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | CloseSocket call. 2024-06-03 22:08:54.919 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:08:54.928 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | Socket gracefully closed by remote side. 2024-06-03 22:08:54.928 | HTTPS connection ID:46 to www.rithmic.com:443 for request ID:46 (1) | Closed. 2024-06-03 22:09:14.573 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:09:14.573 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | New receive buffer size: 0 2024-06-03 22:09:14.573 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:09:14.641 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:09:14.888 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | CloseSocket call. 2024-06-03 22:09:14.888 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:09:14.897 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | Socket gracefully closed by remote side. 2024-06-03 22:09:14.897 | HTTPS connection ID:47 to www.rithmic.com:443 for request ID:47 (1) | Closed. 2024-06-03 22:09:34.542 | 2024-06-03 22:09:34.542 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-06-03 22:09:34.542 | Rithmic Direct - DTC | Remote address is not set. 2024-06-03 22:09:34.542 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-03 22:09:34.542 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:09:34.557 | DTC Client socket (0) | CloseSocket call. 2024-06-03 22:09:34.557 | Rithmic Direct - DTC | Disconnected. 2024-06-03 22:09:34.557 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-03 22:09:54.543 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:09:54.544 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | New receive buffer size: 0 2024-06-03 22:09:54.544 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:09:54.615 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:09:54.881 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | CloseSocket call. 2024-06-03 22:09:54.882 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:09:54.891 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | Socket gracefully closed by remote side. 2024-06-03 22:09:54.891 | HTTPS connection ID:48 to www.rithmic.com:443 for request ID:48 (1) | Closed. 2024-06-03 22:10:14.551 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:10:14.552 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | New receive buffer size: 0 2024-06-03 22:10:14.552 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:10:14.614 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:10:14.867 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | CloseSocket call. 2024-06-03 22:10:14.867 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:10:14.875 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | Socket gracefully closed by remote side. 2024-06-03 22:10:14.875 | HTTPS connection ID:49 to www.rithmic.com:443 for request ID:49 (1) | Closed. 2024-06-03 22:10:34.552 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:10:34.552 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | New receive buffer size: 0 2024-06-03 22:10:34.552 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:10:34.615 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:10:34.852 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | CloseSocket call. 2024-06-03 22:10:34.852 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:10:34.862 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | Socket gracefully closed by remote side. 2024-06-03 22:10:34.862 | HTTPS connection ID:50 to www.rithmic.com:443 for request ID:50 (1) | Closed. 2024-06-03 22:10:54.544 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:10:54.545 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | New receive buffer size: 0 2024-06-03 22:10:54.545 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:10:54.608 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:10:54.876 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | CloseSocket call. 2024-06-03 22:10:54.876 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:10:54.885 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | Socket gracefully closed by remote side. 2024-06-03 22:10:54.885 | HTTPS connection ID:51 to www.rithmic.com:443 for request ID:51 (1) | Closed. 2024-06-03 22:11:14.545 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | Creating socket. Using TLS 1.2. 2024-06-03 22:11:14.546 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | New receive buffer size: 0 2024-06-03 22:11:14.546 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | Connecting to IP: 34.149.87.45. 2024-06-03 22:11:14.616 | Rithmic Direct - DTC | JSON parse error: Invalid value. 2024-06-03 22:11:14.861 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | CloseSocket call. 2024-06-03 22:11:14.861 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | Shutdown started. Waiting for graceful close. 2024-06-03 22:11:14.871 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | Socket gracefully closed by remote side. 2024-06-03 22:11:14.871 | HTTPS connection ID:52 to www.rithmic.com:443 for request ID:52 (1) | Closed. |
[2024-06-03 20:27:45] |
Sierra_Chart Engineering - Posts: 17154 |
You must update Sierra Chart. You are running an old version. Due to changes by Rithmic you must update. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
