Date/Time: Sun, 24 Nov 2024 10:49:37 +0000
[User Discussion] - Low volume nodes (VpB) - Name Label alignment issue
View Count: 150
[2024-06-03 20:04:50] |
iPepe - Posts: 2 |
Hi all, currently I am experiencing an issue with Name Labels in VbP for Volume Valleys, it displays not where it suppose to in chart region, but on price region. See screenshot for visual reference. Any walkarounds for this? Difference between POC,VAH,VAL to LVN |
Attachment Deleted. Sierra issue VpB.png / V - Attached On 2024-06-03 20:04:20 UTC - Size: 163.03 KB - 45 views |
[2024-06-03 20:33:54] |
The POC, VAH, VAL, and VWAP are special items within the Volume by Price study. When you set the "Draw Mode" to be "Volume Profiles & POC, VAH, VAL, VWAP Lines" then these lines are drawn separate from the way other items like the Peaks and Valleys are drawn. Therefore, the alignment is controlled differently. In the end, there is no workaround for this. What you are seeing is how the system current works. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
