Date/Time: Sun, 24 Nov 2024 11:10:59 +0000
Server Data List
View Count: 147
[2024-06-03 17:41:25] |
SierraTraders - Posts: 69 |
When trying to connect to rithmic (File/Data) there is no list in the drop down for server List any suggestion....? |
[2024-06-03 18:15:17] |
Sierra_Chart Engineering - Posts: 17154 |
Update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
