Date/Time: Sun, 24 Nov 2024 10:43:14 +0000
Can't format values between footprints and DOM
View Count: 219
[2024-06-03 16:01:29]
cmack1011 - Posts: 51
PLease see attached pic:
Despite manipulating "Vol at Price multiplier", "value increments per bar in ticks", "market depth combine increments", and "tick size" in chart settings, I cannot get proper alignment and visualization of data across footprints and DOM. Please advise; Thx
imageScreenshot 2024-06-03 at 10.43.44.png / V - Attached On 2024-06-03 15:58:59 UTC - Size: 432.08 KB - 40 views
[2024-06-03 19:39:26]
First, we recommend setting the "Value Increments per Bar in Ticks" (which is related to Chart Drawings anyway), and "Tick Size" back to their defaults.
Then you can manipulate the "Volume at Price Multiplier" and the "Market Depth Combine Increment in Ticks" so you can get the values at the same prices, which is what we assume you are wanting. You should use the same number in both of these settings. So if you set the "Volume at Price Multiplier" to 4, you should set the "Market Depth Combine Increment in Ticks" to 4.
[2024-06-03 23:39:21]
(please see pics) I left the tick size default at 0.01 and the value increments at default of 1 and changed the Vol@Price Multiplier to 4 and 8 and the Market Depth Combine to 4 and then 8, but the volume data in the DOM is still unreadable. Any other way to condense these columns?
imageScreenshot 2024-06-03 at 18.32.56.png / V - Attached On 2024-06-03 23:38:29 UTC - Size: 407 KB - 53 views
imageScreenshot 2024-06-03 at 18.34.08.png / V - Attached On 2024-06-03 23:38:39 UTC - Size: 350.29 KB - 43 views
[2024-06-04 15:04:39]
We have to believe that those columns are the "Current Traded..." columns given the header you have assigned to those. We do not have the "Combine Increment in Ticks" setup to apply to those columns. The "Combine Increment in Ticks" only applies to the main Bid and Ask Market Depth data. You can also have it apply to the "Recent Bid" and "Recent Ask" columns if you set the option for "Chart >> Chart Settings >> Market Depth >> Apply Combine Increment in Ticks to Recent Bid Ask Volume Columns". Refer to the following:
Chart Settings: Apply Combine Increment in Ticks to Recent Bid/Ask Volume Columns (Chart >> Chart Settings >> Market Depth menu)
[2024-06-04 20:48:35]
Ok, Thank you
