Date/Time: Tue, 18 Feb 2025 23:14:22 +0000
spreadsheet question
View Count: 224
[2024-06-03 15:43:08] |
User411320 - Posts: 295 |
Hello, how can I get a numbered column starting from 1 to X. For example, you can put "1" in a cell and pull down and it'll auto populate (2,3,4,5,) and so on.
[2024-06-03 19:27:51] |
John - SC Support - Posts: 38036 |
The easiest way to do this is to put this in a column that is not a "Calculation" column. With the default settings, this would start at Column AA and be all the columns to the right from there. In this case, enter a value of 1 in cell AA3, then enter the following in cell AA4: =AA3 + 1 Then select cell AA4 and select "Spreadsheet >> Copy Formula" and then left click and drag down to select down the column, then select "Spreadsheet >> Paste". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-04 18:32:49] |
that worked thanks
