Date/Time: Sun, 24 Nov 2024 10:29:58 +0000
DELTA FOOTPRINT DATA
View Count: 183
[2024-06-03 15:38:09]
User832560 - Posts: 9
Hello, i am trying to upload a number bars chartbook on sierra charts. Ive downloaded it, and moved it into the data file on sierra charts. It shows up, i can open it, but then nothing appears
[2024-06-03 17:34:54]
Most likely the symbols in the chartbook are not correct for the service you are using. Open the Chartbook and select "Edit >> Translate Symbols to Current Service".
This should take care of it.
