Date/Time: Sun, 24 Nov 2024 10:31:41 +0000
multiple disconnections today
View Count: 152
[2024-06-03 15:33:34] |
User725043 - Posts: 35 |
On 3 separate logins have been disconnected / reconnected three times on 2 of the connections, and twice on the other connection today. Latest Message Log error message attached. Use Internal LAN IP for CME Data and Order Routing (Global Settings >> Sierra Chart Server Settings >> General >> Special) is set to "No" in all three connections. Could you please take a look at my connections and advise? |
Private File |
[2024-06-03 16:23:13] |
Sierra_Chart Engineering - Posts: 17154 |
We do not have the ability to look at these connections. But there is a network issue you are having from your side . We have had a solid connection to the trading server since 2024-05-31 20:07:44.690. No disconnections at all.
