Date/Time: Sun, 24 Nov 2024 10:39:59 +0000
Draw DOM Graph on Chart Display
View Count: 197
[2024-06-03 15:03:22] |
User156989 - Posts: 1 |
Hi, I want to Draw DOM Graph on Chart Display but it doesn't seem not work. Symboy is GCQ24_FUT_CME. I'm on package 11 Denali Exchange Data Feed live via Stage 5. https://www.sierrachart.com/image.php?Image=1717426944370.png https://www.sierrachart.com/image.php?Image=1717426982464.png |
Screenshot 2024-06-03 205819.png / V - Attached On 2024-06-03 15:00:50 UTC - Size: 41.92 KB - 54 views Screenshot 2024-06-03 205848.png / V - Attached On 2024-06-03 15:00:56 UTC - Size: 19.11 KB - 56 views Attachment Deleted. |
[2024-06-03 17:08:04] |
The DOM Graph is working fine. The issue is that you are not getting data that includes Market Depth. Therefore, you only get the 1 level. If you want to change your exchange options for the CME Group, then you can do so at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Note that the exchanges are not pro-rated and renew on a calendar month basis, so any exchange you activate you will pay the full amount for the remaining time in the current month. Also, exchange fees are not refundable, so when you deactivate an exchange, you are only setting it to not renew for the next month - you will still have access to that data through the remainder of the current month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
