Date/Time: Sun, 24 Nov 2024 11:12:54 +0000
Weekly moving averages
View Count: 161
[2024-06-03 14:26:46] |
User449884 - Posts: 155 |
How would i go about setting weekly moving averages? 200 week moving av etc
[2024-06-03 16:59:48] |
The Moving Average studies use a "Length" which is the number of bars. So you would need to determine how many bars make up the 200 weeks worth of data you want to average.
[2024-06-03 23:53:31] |
so using the regular moving average study, how do i set it up to calculate the amount of weeks i want?
[2024-06-04 15:06:04] |
You would have to determine how many bars you have. For instance, if you have 1 day bars, then given that there are 5 trading days in a week and you want 200 weeks, you would need to set the Length to 1000 (5 x 200 = 1000). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
