Date/Time: Sun, 24 Nov 2024 11:04:44 +0000
Daily chart issues
View Count: 148
[2024-06-03 13:15:00] |
moneyboy888 - Posts: 25 |
Hi SC engineers, There seems to be something wrong on the daily chart of UB n TN. Some candle bars are missing, why is that? I've never seen this happening before. Is it due to the recent roll over period? Kindly help n advise. Thank you so much. |
TN daily.png / V - Attached On 2024-06-03 13:14:01 UTC - Size: 1.52 MB - 47 views UB daily.png / V - Attached On 2024-06-03 13:14:11 UTC - Size: 1.35 MB - 46 views Attachment Deleted. |
[2024-06-03 13:17:47] |
Sierra_Chart Engineering - Posts: 17154 |
These charts are too complicated. Only post an image of a chart following these instructions here: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) If there is missing data, then refer to: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
