Date/Time: Sun, 24 Nov 2024 10:31:16 +0000
Accidently put +1 in my Trial Activation!
View Count: 186
[2024-06-03 02:13:52] |
User976 - Posts: 8 |
Accidentally put +1 in my Trial Activation, when it was supposed to be just 1(number)! It's not allowing me to send any more text messages. (Please don't put my # publicly in the post), but I would love to activate the trial to see other tickers like NQ. Thank You!
[2024-06-03 02:18:45] |
Sierra_Chart Engineering - Posts: 17154 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. To get started with Sierra Chart, follow the Sierra Chart setup instructions here: Sierra Chart Setup Instructions 1 After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-03 02:44:13] |
Okay Thank You! and I just setup a brand new Chartbook that took me 2 hours, if I save it and close sierra.. it should still be there right? Read some comments that if I close something specific or something, that the whole thing might be gone? Thank You! |
[2024-06-03 15:51:24] |
As long as you properly save the Chartbook, the setup will be there when you re-open it.
