Date/Time: Sun, 24 Nov 2024 12:02:59 +0000
Large Volume Indicator not showing on main graph
View Count: 173
[2024-06-02 15:31:04] |
luwis01 - Posts: 1 |
I cannot get two studies to show on my main price chat (which is the chart with CVD and 5000 volume bars). I have tried everything and gone through the self help with no luck. Can you please help? Attached is the updated workbook with the two studies which are not visible on my chart. Thanks, |
G7FX_FULLDECKES_updatedJan2023-230106-184113.Cht - Attached On 2024-06-02 15:30:02 UTC - Size: 34.56 KB - 204 views |
[2024-06-02 16:01:25] |
Sierra_Chart Engineering - Posts: 17154 |
First: Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
