Date/Time: Mon, 12 Oct 2026 16:46:29 +0000
Load Study Collection Removal of Existing Studies
View Count: 1199
| [2024-06-02 07:12:27] |
| User173763 - Posts: 14 |
Hi, When I have existing studies in a chart and trying to load a saved collection, in addition to these, i am not able to do so. There is a "plus"(+) symbol appended on the file name of the saved collection when I check the box "Prompt to remove existing studies". As a result, windows cannot find the filename of the study and the whole thing fails. Getting an error 2024-06-02 02:52:50.681 | Error opening Study Collection file for determining internal version. C:\SierraChart\Data\TYP_ZigZag+.StdyCollct. Windows error code 2: The system cannot find the file specified. * Thanks |
| [2024-06-02 19:26:01] |
| Sierra_Chart Engineering - Posts: 25146 |
How exactly are you doing this: and trying to load a saved collection,
| [2024-06-03 15:38:44] |
Hi, Step 1. Open Studies, choose a study collection on the "save studies as study collection" Step 2. Select Checkbox "Prompt to remove existing studies" Step 3. Hit Load Step 4. Pop-up "Clear Existing Studies on Chart" Step 5. Select No Step 6. Get the error message Thanks |
Attachment Deleted. |
| [2024-06-03 19:15:35] |
| John - SC Support - Posts: 48181 |
There is an issue if you load the Study Collection that way with what you are trying to do. You had not already saved the Study Collection with the + sign after it, which gives you the prompt to remove other studies or not. If you want to do this, you would need to save the Study Collection first with the option for Prompt to Remove Existing Studies already enabled. Another option, that forces you do to this is to load the Study Collection from the Analysis menu, as you have to have it saved first in order to access it there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
