Date/Time: Thu, 10 Sep 2026 23:12:04 +0000
[Programming Help] - Help in a custom study code and function
View Count: 595
[2024-06-02 04:46:16]
User862183 - Posts: 2
Hello everyone,
I'm trying to create an indicator that shows me the ratio between passive orders (pulling/stacking) and aggressive orders at any given time.
So I've started coding in acsil to do this
Hello everyone,
So I've started coding in acsil to do this.
Here's the code I have at the moment, although I've added two imaginary functions ( sc.GetOrderFlowPullingStackingData(index) and sc.GetOrderFlowAggressiveOrdersData(index)). One function for pulling stacking and the other for aggressive orders at time T.
But I don't know the real sierra chart functions that do this. I need to replace them with the actual functions provided to get the passive and aggressive order data. But I don't know which ones it is.
I don't know if you understand my problem and if you have a solution but it would help me a lot.
Thank you for reading and for any help you can give me.
here the code
#include "sierrachart.h"
SCDLLName("Pulling/Stacking vs Aggressive Orders")
SCSFExport scsf_PullingStackingVsAggressiveOrders(SCStudyInterfaceRef sc)
SCSubgraphRef RatioLine = sc.Subgraph[0];
SCInputRef PullingStackingWindow = sc.Input[0];
SCInputRef AggressiveOrdersWindow = sc.Input[1];
if (sc.SetDefaults)
sc.GraphName = "Pulling/Stacking vs Aggressive Orders";
sc.StudyDescription = "Displays the ratio between pulling/stacking and aggressive orders.";
RatioLine.Name = "Ratio";
RatioLine.DrawStyle = DRAWSTYLE_LINE;
RatioLine.PrimaryColor = RGB(255, 0, 0); // Red
PullingStackingWindow.Name = "Pulling/Stacking Window (seconds)";
PullingStackingWindow.SetInt(10); // Default window of 10 seconds
AggressiveOrdersWindow.Name = "Aggressive Orders Window (seconds)";
AggressiveOrdersWindow.SetInt(10); // Default window of 10 seconds
sc.AutoLoop = 1; // Automatically loop through the data
return;
// Variables to store pulling/stacking and aggressive orders data
float totalPullingStacking = 0.0;
float totalAggressiveOrders = 0.0;
// Get the current time index
int currentTimeIndex = sc.Index;
// Define the window size based on the input settings
int pullingStackingWindowSize = PullingStackingWindow.GetInt() * sc.UpdateInterval;
int aggressiveOrdersWindowSize = AggressiveOrdersWindow.GetInt() * sc.UpdateInterval;
// Calculate pulling/stacking orders over the specified window
for (int i = 0; i < pullingStackingWindowSize; ++i)
int index = currentTimeIndex - i;
if (index < 0) break;
// Hypothetical function to get pulling/stacking data
totalPullingStacking += sc.GetOrderFlowPullingStackingData(index); // Replace with the actual function
// Calculate aggressive orders over the specified window
for (int i = 0; i < aggressiveOrdersWindowSize; ++i)
// Hypothetical function to get aggressive orders data
totalAggressiveOrders += sc.GetOrderFlowAggressiveOrdersData(index); // Replace with the actual function
// Calculate the ratio
float ratio = 0.0;
if (totalAggressiveOrders != 0)
ratio = totalPullingStacking / totalAggressiveOrders;
// Set the calculated ratio to the subgraph
RatioLine[sc.Index] = ratio;
