Date/Time: Sun, 24 Nov 2024 11:06:55 +0000
TPO High Low Lines for Separate Periods
View Count: 235
[2024-06-02 01:39:43]
User303857 - Posts: 74
Hello Support Team
On a TPO 15 minute
I would like to be able to have high/low lines for several periods during the current session.
I have tried both:
The High/Low for Time Period and High/Low for Time Period - Extended studies.
On the Extended there is only one line from the previous day and not the current day and that line does not show up if I set the days to calculate less than 3.
On the High/Low for Time Period I get nothing...
Is it possible to plot high low lines for the TPO using the 30 minute or smaller 15 or 5 minute?
Or is it necessary to use the line at time study which would be two for each period?
[2024-06-03 14:45:38]
we are not really understanding what you are wanting to do.
Please give us the exact situation you are trying to solve.
[2024-06-03 16:24:31]
John I see this from one of you previous posts:
This may be only option. Here is a picture of the high/low lines for E period...
Is this a possible feature to be added in the future to a TPO since it has every other type of line option in the sub graphs?
Thank You !!!
John - SC Support [Direct Messages] - Posts: 31977
The High and Low of a TPO are just the high and low of the time period that the TPO covers. Therefore, you can use the Daily OHLC, or the High/Low for Time Period or High/Low for Time Period Extended. There are other studies as well that you can use to get the High and Low, it really just depends on how far forward you want to extend the lines and the time period of the TPOs.
Refer to the following for the above mentioned studies:
Daily OHLC
Date Time Of Last Edit: 2024-06-03 16:25:26
imageE PERIOD HIGH LOW LINES.png / V - Attached On 2024-06-03 16:23:57 UTC - Size: 59.82 KB - 49 views
[2024-06-03 19:57:14]
In order to get the High/Low of a Sub-Period within a TPO Profile, you would need to know the time of that sub-period and then use the "High/Low for Time Period" on a standard chart (you can not do this on a TPO Profile chart) and set the start and end times to that sub-period start and end times.
You could then overlay that study on the TPO Profile chart in order to view it there.
Refer to the following:
Study/Price Overlay Study
