Date/Time: Sun, 24 Nov 2024 11:13:14 +0000
Chart trading settingas - weird info positioning
View Count: 247
[2024-06-01 18:29:30] |
VLiviu - Posts: 223 |
Hi I don't know if this is normal or I need to change some settings, please see the attached picture. All the trading info is weird positioned under and above the candles. Last trade (upper right corner) doesn't even show the place where I took profit. (I think it appears after candle closes) Thanks Date Time Of Last Edit: 2024-06-01 18:51:02
SC-trading.png / V - Attached On 2024-06-01 18:29:22 UTC - Size: 377.73 KB - 54 views |
[2024-06-03 14:44:20] |
What you are seeing is normal. There is not a way to change the location of the order fill information, it will be above/below the candles. Refer to the following for what information you can include in the order fill line: Global Trade Settings Windows: Order Fills (Global Settings >> Chart Trade Settings >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-03 15:00:01] |
yeah, already saw the docs thanks! |
