Date/Time: Sun, 24 Nov 2024 11:31:46 +0000
[User Discussion] - hot key to move stop
View Count: 216
[2024-06-01 17:28:10]
User722905 - Posts: 9
I USE A PROGRAMABLE KEY PAD TO SET TRADING HOT KEYS. I USE THE THREE KEY GROUP "CTRL+ALT+U" TO MOVE THE STOP UP ONE TICK.
I PROGRAM THE KEYPPAD KEY WITH FOUR IDENTICAL GROUPS OF "CTRL+ALT+U", TO MOVE THE STOP UP FOUR TICKS.
IT WORKS PERFECTLY ON SIM TRADE, WHEREAS IT WORKED ON LIVE TRADING FOR A LONG TIME ON VERSIONS PRIOR TO 2643.
