Date/Time: Sun, 24 Nov 2024 10:31:38 +0000
Hotkey to move stop order
View Count: 251
[2024-06-01 17:18:52] |
User674409 - Posts: 24 |
Is there any hotkey i can enable, so when i see a big order against my position on the dom, i can press that key and my stop order moves automatically, let say 2 ticks behind the current price? So in that way, i can protect myself from a bigger lost or protect what i already gained. I already try with the "move attached stops to price", but that requieres to follow the price with the mouse, and when there is a lot of volatily its a little crazy to follow the price with the mouse. The eyes can be faster and with a hotkey will be amazing, thanks
[2024-06-03 14:32:18] |
There is not a way to move the Stop to an offset from current price. The closest available would be to use the "Move to Breakeven" option and use the Offset value to have it moved offset the actual breakeven. Refer to the following: Basic Trading and the Trade Window: Main/C >> BE (BreakEven button) To do exactly what you want, you could create a custom study that can be setup with a keyboard shortcut. Refer to the following: Automated Trading From an Advanced Custom Study: Modifying an Order List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
