Date/Time: Sun, 24 Nov 2024 10:43:22 +0000
Trade Targets shortcut
View Count: 242
[2024-06-01 14:50:08] |
User937068 - Posts: 10 |
Hi I created myself a few trade targets and i switch between them depending on the situation. Is there a shortcut i can make to switch between targets more easily? Currently i use the mouse but it's way to slow that the way i want it. I attach what exactly i mean. |
[2024-06-03 14:22:44] |
Refer to the following: Control Bar: Control Bar Trade Window Configuration Buttons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-03 16:43:49] |
Awsome. Thank you. |
