Date/Time: Sun, 24 Nov 2024 10:40:08 +0000
Eurex Data
View Count: 303
[2024-06-01 08:15:33] |
skalaydzhiyski - Posts: 58 |
Hi guys, just enabled the EUREX data feed from Denali + I am using Interactive Brokers for execution. My question is why do I only see 16 futures symbols under EUREX ? Apparently there are a lot of single stock futures that are also supposed to be traded there, but I can't see any of those symbols. I don't particularly trade single stock futures so that's not an issue for me - I just want to confirm that my setup of the data feed is correct. All the best, Spas |
[2024-06-02 18:52:14] |
Sierra_Chart Engineering - Posts: 17154 |
Sierra Chart is not going to list all of the EUREX symbols for Interactive Brokers. We will not be doing that for Interactive Brokers.
[2024-06-02 18:58:52] |
Okay, but does the denali data feed support those symbols, presumably not right ?
[2024-06-03 15:38:05] |
Our Denali Exchange Data Feed has support for all the EUREX symbols. We just do not have all of them listed in the Futures-EUREX section.
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-03 16:23:38
[2024-06-03 16:00:48] |
great! good to know. Thank you |
[2024-06-03 16:24:43] |
This is not entirely true. There is no support for EUREX spreads (they are just way too complicated with no standard symbology) , and we do not know about any single stock futures. You only have access to what is listed. The more complete list is when using the service SC Data-All Services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
