Date/Time: Thu, 19 Sep 2024 22:10:47 +0000
Numbers Bars Study problem
View Count: 1044
[2014-08-20 16:40:43] |
User86139 - Posts: 10 |
Hello, Numbers Bars Study is not showing at all on my chart. I just get a blank screen with this study. I have obviously tailored the settings to my requirements. I also have numbers bars calculated values on my chart and that is working well. Please help. Regards |
[2014-08-20 17:25:13] |
What happens when you remove all studies from the chart and add a new Numbers Bars study to it?
[2014-08-21 12:53:00] |
The same result...no numbers bars. The normal candlesticks have gone and the RH side vertical values is reacting to price changes. Am using SC exchange data and DYU14(M)in Eurex Regards |
[2014-08-21 16:02:45] |
Reset the Numbers Bars study to a default state by following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#CustomDefaultStudySettings Refer to the section titled: Resetting Default Study Settings For an Individual Study After the study is reset, remove it from the chart and add it again. If there still is a problem, then post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
