Date/Time: Sun, 24 Nov 2024 13:53:24 +0000
message
View Count: 157
[2024-05-31 13:54:43]
User285770 - Posts: 41
What is this message?
What should I do?
imageScreenshot 2024-05-31 165026.png / V - Attached On 2024-05-31 13:51:06 UTC - Size: 641.09 KB - 43 views
[2024-05-31 17:21:32]
Start by rebooting your computer. As the message states, this should just be temporary and rebooting will reset your computer's routing information, so hopefully this will resolve it.
If this does not resolve the issue, then you would need to check with Rithmic to see if they are having a problem of some kind that is causing you to continue to get this message.
