Date/Time: Sun, 24 Nov 2024 11:49:36 +0000
Profil copy trading
View Count: 268
[2024-05-31 09:53:04]
Fungraphic72 - Posts: 6
Hello, can you add a profile system for copy trading?
Example:
I have 10 apex accounts, and I would like to make 2 copy profiles.
1 profile with accounts 1,2,3,4,5 and 1 profile with accounts 6,7,8,9,10.
That way, you don't have to fill in everything each time.
image2024-05-31 11_51_47-Clipboard.png / V - Attached On 2024-05-31 09:52:12 UTC - Size: 15.62 KB - 43 views
[2024-05-31 16:59:48]
You can include the "Order Allocation to Trading Accounts" setup in the Trade Configurations. Then you would change your trade configuration in order to have the allocation setup as you want. Refer to the following:
Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Linking
[2024-05-31 17:28:47]
I don't understand how you can make different configurations with the existing settings.
I think it would be more practical to be able to make different profiles, like for logging in to different accounts.
Like on the attached screen.
image2024-05-31 19_27_40-Clipboard.png / V - Attached On 2024-05-31 17:28:34 UTC - Size: 23.89 KB - 48 views
