Date/Time: Tue, 15 Sep 2026 04:58:43 +0000
[User Discussion] - Distinguish the currently active chart from others ?
View Count: 626
[2024-05-31 08:19:03]
BenjFlame - Posts: 353
is there a visual way, a setting, a color to distinguish the currently active chart from the others ? In particular if the chart's title bar is hidden.
[2024-05-31 15:12:17]
Tony - Posts: 725
can be easily done with ACSIL, what would be ideal signal you prefer? i.e. a word "Active" or a colored square on the top right corner of the chart? If it's not too fancy, I will write a study and post here.
[2024-05-31 16:07:10]
Thank you.
A sky blue square would be great.
[2024-05-31 17:12:23]
Tony - Posts: 725
This one was tested and works, you will have to load this study in each chart window. I think it would be more efficient if you could work on Subgraphs if you have custom studies in your chart, by checking this condition:
sc.ChartWindowHandle == GetFocus()
In case you need instructions on how to build custom studies from source code, here is the link:
How to Build an Advanced Custom Study from Source Code
Here is the code for the study:
#include "sierrachart.h"
SCDLLName("ChartActivated")
SCSFExport scsf_ChartActivated(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    sc.GraphName = "Chart Activated";
    sc.GraphRegion = 0;
    sc.AutoLoop = 1;
    sc.UpdateAlways = 1;
    sc.Input[0].Name = "Vertical Position";
    sc.Input[0].SetInt(92);
    sc.Input[1].Name = "Horizontal Position";
    sc.Input[1].SetInt(120);
    sc.Input[2].Name = "Square Size";
    sc.Input[2].SetInt(2);
    sc.Input[3].Name = "Square Color";
    sc.Input[3].SetColor(127,127,255);
    return;
  s_UseTool Tool;
  Tool.Clear();
  Tool.ChartNumber = sc.ChartNumber;
  Tool.LineNumber = 74191;
  Tool.DrawingType = DRAWING_RECTANGLEHIGHLIGHT;
  Tool.UseRelativeVerticalValues = 1;
  Tool.BeginDateTime = sc.Input[1].GetInt();
  Tool.EndDateTime = sc.Input[1].GetInt() + (sc.ChartWindowHandle == GetFocus() ? (int)(sc.Input[2].GetInt()*2.5) : 0);
  Tool.BeginValue = sc.Input[0].GetInt();
  Tool.EndValue = sc.Input[0].GetInt() + (sc.ChartWindowHandle == GetFocus() ? sc.Input[2].GetInt() : 0);
  Tool.LineWidth = 0;
  Tool.SecondaryColor = sc.Input[3].GetColor();
  Tool.AddMethod = UTAM_ADD_OR_ADJUST;
  sc.UseTool(Tool);
Date Time Of Last Edit: 2024-05-31 17:31:49
[2024-06-02 13:45:15]
Thank you very much. It works well. Well done !
