Date/Time: Sun, 24 Nov 2024 14:01:28 +0000
TPO Profiles
View Count: 171
[2024-05-30 20:12:48] |
User784191 - Posts: 2 |
hi, I have volume for every day, but when I change the time frame to daily, I got one big volume. I am sending two pictures of how I have it and how I would like it
tmp_1717098303_help 41.PNG / V - Attached On 2024-05-30 20:12:22 UTC - Size: 35.63 KB - 40 views tmp_1717098303_help 1.PNG / V - Attached On 2024-05-30 20:12:26 UTC - Size: 242.89 KB - 46 views |
[2024-05-30 20:14:09] |
If you want to view the TPO profiles per day, then do not change the Bar Period to be daily. Leave it at some intraday setting (1 minute, 5 minutes, etc.). Then on the TPO Profile Inputs you set the length for the TPO period to be 1 day. The system will work out the rest from there. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Basic Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
