Date/Time: Sun, 24 Nov 2024 13:54:51 +0000
Study: Horizontal Lines
View Count: 202
[2024-05-30 19:09:33]
User688525 - Posts: 257
Hello Sierra Chart,
Is it possible to "import" line values for the Horizontal Lines study versus manually adding each value?
Thank you
[2024-05-30 19:34:51]
There is not a built-in function to do this, but you can always build one by modifying the study, or even creating your own. Refer to the following:
How to Build an Advanced Custom Study from Source Code
List of Third Party Sierra Chart Study and System Programmers
[2024-05-30 21:05:39]
Hello John,
Thank you!
[2024-05-31 01:03:17]
User584084 - Posts: 262
2 ways you can import data from a CSV file:
1) https://www.youtube.com/watch?v=0R73EQxfeGY
The example google sheet is password protected. Go to File >> New File >> Spreadsheet. Then copy all the data to the new spreadsheet. Or File >> Make Copy. Then use the new spreadsheet. I think either should work.
Go to the Share button in the upper right hand corner. Allow General Access to anyone who has the link.
Or 2) https://www.simplesystemtrading.com/autolevels/
[2024-05-31 06:17:40]
Hi User584084,
Thank you for the video and link to the Auto Levels study.
Cheers!
