Date/Time: Sun, 24 Nov 2024 13:53:28 +0000
change DOM COLOURS SETTINGS
View Count: 192
[2024-05-30 16:25:14] |
User732755 - Posts: 2 |
Hi How can I change colour settings on DOM chart. Having problems changing background colour. PLS HELP ME CHANGE DOM BACKGROUND SETTINGS.I HAVE BEEN TRYING TO CHANGE DEFAULT BACKGROUND COLOUR TO BLACK BUT COULD NOT DO SO. Pls help Thanks A. |
[2024-05-30 17:12:37] |
Is this a Chart or a Trading DOM? If a Trading DOM, are you wanting the entire background black, or do you want a different color for above the current price and below the current price? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-31 07:30:17] |
Flowdity - Posts: 46 |
you can check this document Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM there is two ways to do this 1, per chart basis you need to disable global grapic setting 2, set it globally, it will work for every dom you open up. |
