Date/Time: Sun, 24 Nov 2024 13:50:17 +0000
FXCM data feed not loading
View Count: 157
[2024-05-30 16:11:07] |
JR2R - Posts: 20 |
HI for some reason my data feed for fxcm on USDCHF and EURUSD has stopped loading this morning from 9am. Please fix this
FXCM data feed.png / V - Attached On 2024-05-30 16:11:02 UTC - Size: 122.88 KB - 45 views |
[2024-05-30 16:12:07] |
We are not seeing any issues with the data feed at this time. If you are still having issues then please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
