Date/Time: Fri, 30 Oct 2026 14:50:49 +0000
Persistant SCString
View Count: 2026
[2014-08-20 14:47:02]
jackw - Posts: 57
I have a SCString (max 32 chars) that I want to be persistant between calls to the study. Do you have some sample code that shows how to do this?
[2014-08-20 17:07:01]
You would have to allocate memory and then release the memory. Refer to:
ACSIL Programming Concepts: Dynamic Memory Allocations Within Study Instance
[2014-08-20 23:42:38]
jackw - Posts: 57
Based on your example I wrote the short study I've attached to test out dynamically allocating memory.
When I allocate a single instance of the strucure, the programs compiles and runs fine.
student = (s_studentdata *) new s_studentdata;
When I allocate an array of the structure, the program still compiles and runs, but SC crashes when I remove the study or close the chartbook.
student = (s_studentdata *) new s_studentdata[10];
NEVERMIND!!! I figured out the problem. I was releasing the memory allocated to the array using the syntax 'delete' when I should have been using delete[]. You example code has the same error.
Date Time Of Last Edit: 2014-08-21 05:00:02
[2014-08-21 07:31:52]
Yes, this is correct:
http://msdn.microsoft.com/query/dev10.query?appId=Dev10IDEF1&l=EN-US&k=k%28DELETE_CPP%29;k%28DELETE%29&rd=true
Here is another example which uses the internal allocation and free functions.
SCSFExport scsf_DynamicMemoryAllocationExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Dynamic Memory Allocation Example";
    sc.AutoLoop = 1;
    // This should be set to 0 when using new and delete in a study function.
    sc.FreeDLL = 0;
    return;
  // Do data processing
  double * p_DoubleArray = (double*)sc.PersistVars->i1;
  if(sc.LastCallToFunction)
    if(p_DoubleArray != NULL)
      sc.FreeMemory( p_DoubleArray);
      sc.PersistVars->i1 = NULL;
    return;
  if(p_DoubleArray == NULL)
    //Allocate an array of 1024 doubles.
    p_DoubleArray = (double *) sc.AllocateMemory( 1024 * sizeof(double) );
      sc.PersistVars->i1 = (int)p_DoubleArray;
    else
      return;
  //assign value to one of the elements
  p_DoubleArray[0] = 100;
  return;
Date Time Of Last Edit: 2014-08-21 07:32:07
