Date/Time: Sun, 24 Nov 2024 13:54:27 +0000
Reducing profile bar width for Numbers Bars setting.
View Count: 160
[2024-05-30 16:02:59] |
User476186 - Posts: 3 |
Hello, I was wondering if there's a setting to reduce the bar width on the Numbers Bars setting. My current study setting is set to show text of Ask Vol Bid Vol Difference, and background type is Ask Bid Difference Profile. As you can see, the width of the profile extends into the text which makes it hard for me to read it based on my current color scheme. I was wondering if there's a setting to reduce the width of the bar? I have attached an image for your reference. Thank you. |
Attachment Deleted. Screenshot 2024-05-31 000005.png / V - Attached On 2024-05-30 16:00:29 UTC - Size: 8.76 KB - 43 views |
[2024-05-30 17:07:43] |
There is not a way to set the bar length to not go over the text. The best option is to either change the Text Color or to color the text based on some property and use the option to color the text using different coloring options. Refer to the following: Numbers Bars: Default Text Color Numbers Bars: Use Separate Colors for Text Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
