Date/Time: Tue, 22 Sep 2026 11:40:40 +0000
Trade Lock specific DOMs / chart only
View Count: 1552
| [2024-05-30 13:03:51] |
| Woodzy - Posts: 35 |
Is there any way to use Trade Lock on specific DOM's / Charts only rather than the all or nothing platform wide option we have now? I have a few chart DOMs up but don't want to trade of some of them, but if I turn Chart Trade Mode off on those charts then the DOM is closed. The only other option I'm considering is starting a new instance for live execution charts only, is that the best way around this? |
| [2024-05-30 14:43:01] |
| John - SC Support - Posts: 47955 |
For charts (not Trading DOMs), you can set the option for "Trade >> Chart Trade Mode On" to not be enabled. You will not be able to enter or view orders on that chart. There is not a way to turn off a Trading DOM. The only here would be to remove the Trading DOM altogether. The other option you mention of using a separate instance will work as well. This is our recommendation for lowest latency trading in general. Refer to the following: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-10 02:33:18] |
| User745789 - Posts: 398 |
Woodzy - I found another solution on the forum: for no-trading DOMs, set to require order confirmation. See M menu in Trade Window for each non-trading DOM.
| [2024-07-10 09:24:21] |
Good idea User745789, yes that works. I would have to disable order confirmations in Global Chart trade settings first, before configuring the individual DOMS. In the end I have settled for separate Sierra instances for my Live execution DOMs anyway as this also spreads any CPU load to give them best performance. |
