Date/Time: Sun, 24 Nov 2024 08:25:32 +0000
Usage issues
View Count: 248
[2024-05-29 22:13:20] |
User204571 - Posts: 4 |
I used a template provided by someone else and it has already been loaded, but the market situation is not realistic. Is it because I didn't set it up correctly? And will such pop ups often appear? I don't understand what happened |
微信截图_20240530060757.png / V - Attached On 2024-05-29 22:12:42 UTC - Size: 365.1 KB - 41 views 微信截图_20240530060921.png / V - Attached On 2024-05-29 22:12:45 UTC - Size: 491.08 KB - 43 views Attachment Deleted. |
[2024-05-30 15:58:35] |
Our servers show that your "Current Selected Service" is set to "Interactive Brokers". As such, the symbols in that chartbook are not correct for that service. Select "Edit >> Translate Symbols to Current Service" in order to update the symbols for the chartbook to what is needed for Interactive Brokers.
[2024-06-04 20:15:29] |
How can I directly view real-time market trends?
[2024-06-04 20:15:30] |
[2024-06-04 20:36:38] |
We need more information. What exactly are you looking for? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-05 00:14:57] |
Tony - Posts: 516 |
你也可以用中文提问,Sierra团队用谷歌翻译来处理其他语种的问题。
[2024-06-10 18:06:53] |
What should I do to load data properly?
微信截图_20240611020605.png / V - Attached On 2024-06-10 18:06:24 UTC - Size: 1.05 MB - 40 views |
[2024-06-10 19:55:17] |
If you are referring to the zeros in the Numbers Bars, then this is because Interactive Brokers is not supplying the Bid and Ask information for historical data. The solution is to use our Denali Exchange Data Feed instead, which gives you the correct information for historical data. Refer to the following: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
