Date/Time: Sun, 24 Nov 2024 13:39:12 +0000
NUMBERS BARS STACKED AND LARGE3 IMBALANCES
View Count: 263
[2024-05-29 12:49:10]
User110225 - Posts: 18
Hello.
On my numbers bars study, I have my column 1 percent compare thresholds set to 0.25, 0.5, 3. This is good as it shows stacked imbalances that are 3 times larger (300%)
I would like to also have extreme imbalances of 1000% highlighted on the same study at the same time in a a different colour.
I have set up 2 numbers bars studies on my graph, one set for the 300% and one set for 1000%. It seems that I can only have 1 of them highlighted at a given time, and not both.
The software always shows on the 300% study, and will only show the 1000% study when the 300% study is hidden.
Could you please help with having them both show at the same time.
Best wishes
Chris
[2024-05-29 14:04:48]
Sierra_Chart Engineering - Posts: 17156
You need to have a separate chart for every instance of the Numbers Bars study.
