Date/Time: Sun, 24 Nov 2024 11:02:42 +0000
Dom order ladder doesnt work for one of my dom
View Count: 206
[2024-05-29 02:39:26]
User581066 - Posts: 27
I have package 5 using the delayed data for sim trading and my dom ladder doesnt work on my DOM (CL crude oil). When i click on the bid or ask to either do a market or limit order nothing shows up as you can see on the attached video. But when i use the dom order ladder on another DOM (ES) the ladder works fine as you can see in the video.
Private File
[2024-05-29 06:50:21]
Sierra_Chart Engineering - Posts: 17154
Check the configuration :
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
Make sure these two columns are in the Visible Columns list:
Bid Size/Buy Column
Ask Size/Sell Column
[2024-05-29 23:43:00]
Hi checked and yes those 2 are in the visible columns list.
This afternoon i was able do use the dom ladder for CL, during the RTH session around 3pm EST. Everything worked fine.
Then i conected again at 7.30pm EST and the problem is back.
Note that Every Time i click on the bid or ask to enter a limit or market order, i can see in the trade order window : «Status: Canceled »
[2024-05-30 01:06:09]
Edit: it is 21.04 EST and i can make Orders thought the Dom,maybe because i allowed the use of evening session in chart settings==> « session Times »
[2024-05-30 02:16:59]
So is it a case where an order is being submitted but then canceled? See if an order is added to the Trade >> Trade Orders Window when it seems like an order is not submitted.
It is not supported to submit a market order through the Chart/Trading DOM. That order type is not supported in that interface.
Date Time Of Last Edit: 2024-05-30 02:18:04
[2024-05-30 11:38:50]
Yes an order is added to the trade order window but the status goes directly to canceled. But note that after like 15min into the globex session I was able to pass my sim orders on the dom.
Also, what do you mean by « It is not supported to submit a market order through the Chart/Trading DOM »? As i told you i was able to submit simulation orders trought the trading dom and i did it for months before with your Doms.
Date Time Of Last Edit: 2024-05-30 11:39:49
[2024-06-04 20:56:53]
If the order is being canceled, provide us a line from the Trade Activity Log where it gets canceled:
Trade Activity Log: Providing Trade Activity Log Data Lines to Support
The Chart/Trading DOM buy and sell columns do not support market orders:
Global Trade Settings Windows: Chart DOM Settings
There is no option for that order type.
