Date/Time: Sun, 24 Nov 2024 14:09:39 +0000
[Programming Help] - Replay
View Count: 139
[2024-05-28 23:39:19] |
User72965 - Posts: 115 |
Got a change notice today~~ I have no Replay:Can't open it up to use~~ Sent An post days ago> Did you get it??? I don't think This "change" Had anything to do with my issue~ Says no reply needed on today's notice~~ When I select Replay chart Seems it is not making the connection Thx Gene :) |
[2024-05-29 12:04:54] |
ertrader - Posts: 672 |
I had a similar issue... try clicking the "reset replay control panel windows"...it's the last selection in /chart/replay chart/reset replay control panel window |
