Date/Time: Sun, 24 Nov 2024 13:56:10 +0000
issue with the trade activity --> period stats
View Count: 199
[2024-05-28 17:10:11]
User61576 - Posts: 443
attached are screenshots of the trade activity --> period stats (based on the simulated feed)
this is 30 min breakdown
pls check (this is an example as it happens on other time frames)
on the slot of 13:30 between 01/22/24 to 05/21/2024 the pnl is +3546 on 133 trades
on the slot of 13:30 between 01/22/24 to 05/28/2024 the pnl is -2337 on 142 trades
so I would expect that on the range of date 22-28 i will lose 3546- -2337 = 5883 lose.
but when I check in the activity log the range between 05/22 to 05/28, on the same time slot, I get only -623.8 on 10 trades
so my question how is the total range of dates don't sums up the 2 periods of that same range of time?
that happen in other time slots as well (09:30, 11:00,12:00)
Can it be that the calculation here is having an issue?
version 2634, only 1 symbol+ expiration is selected (NQM24)
Private File
Private File
Private File
[2024-05-28 20:37:26]
Sierra_Chart Engineering - Posts: 17156
We cannot answer this. This requires extensive analysis which we do not do as a matter of policy:
Trade Activity Log: Questions About the Trade Activity Log Data
