Date/Time: Sun, 24 Nov 2024 14:03:31 +0000
attached orders disappearing
View Count: 308
[2024-05-28 16:47:03] |
SafSaf - Posts: 89 |
hi i have an order with a buy stop and a buy limit open on the euro/usd mini's atm and i want to let the order run over night. in the past, on a number of occasions, i've come back to my charts in the morning to find the order is still live but the attached orders have disappeared. how do i stop this from happening please?
[2024-05-28 16:47:18] |
Sierra_Chart Engineering - Posts: 17156 |
You need to set the Time in Force for Attached Orders to Good till Canceled: Attached Orders: Time In Force Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-28 21:21:21] |
Make sure you are setting the Time in Force for the Attached Orders for the correct Trade Window: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Each chart and trading DOM has its own window. And check the reason why the Attached Orders are being canceled, in the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-28 21:25:30
[2024-05-31 07:22:21] |
Ok, so your advice worked and this morning everything was in place and I made a profit of around 8 points…. However… after flattening my position the profit disappeared from the trade window completely and both the p&l pane and dpl pane show zero profit. To double check, I enabled my positions to check my entry point and exit points on the chart and they are non existent too…. It’s As if the trade never existed. I don’t understand what’s going on? |
[2024-05-31 07:24:18] |
One other thing… does sierra charts record the actual profit and loss in $’s rather than positions so I can keep a track of my activity in dollars rather than just fills?
[2024-05-31 16:47:59] |
With regards to the P/L - the Daily P/L is just that - daily. Since the trade took place across the day, it is not showing in there. And the Open P/L will only show for the open trades. So what you are seeing is correct, but the trade did occur. You would have to look at the P/L for the trade in the Trade Activity Log. In order to view P/L in dollars, or some other format, refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
