Date/Time: Sun, 24 Nov 2024 13:23:17 +0000
Numbers bars spacing
View Count: 219
[2024-05-28 15:29:25] |
User480109 - Posts: 36 |
I like the Numbers bars chart spacing to be tight all the time so there's no horizontal space between the boxes. I noticed that as time continues, it sometimes automatically updates with this horizontal space. Which settings do I use so it's always no space between the numbers bars? Pls see attached screenshot
Date Time Of Last Edit: 2024-05-29 06:51:42
NumbersBarsSpace.JPG / V - Attached On 2024-05-28 15:29:07 UTC - Size: 90.66 KB - 72 views Attachment Deleted. |
[2024-05-29 14:01:49] |
Sierra_Chart Engineering - Posts: 17156 |
You need to increase the range of prices displayed in the chart, to decrease the vertical spacing between the boxes. Use Interactive Scale Range: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale There is nothing else that can be done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-29 14:01:57
