Date/Time: Sun, 08 Sep 2024 02:08:02 +0000
Spreadsheet alerts generated before candle close
View Count: 160
[2024-05-28 11:17:45] |
AzharBasri - Posts: 28 |
Hi, I'm using spreadsheet to send the alert to telegram. The alerts has been sent normally to telegram but I realised that the alert generated from the spreadsheet is triggered before the candle close thus giving a false signal. Is it possible to get the alerts be generated only after the previous candle closed like in columns K,L,M,N when I'm using other columns? Thanks |
[2024-07-18 20:14:03] |
Sierra_Chart Engineering - Posts: 16292 |
Is it possible to get the alerts be generated only after the previous candle closed like in columns K,L,M,N when I'm using other columns? Thanks Refer to these Inputs: Spreadsheet Systems, Alerts and Automated Trading: Signal Only on Bar Close We do not know what you mean by this: when I'm using other columns?
