Date/Time: Sun, 24 Nov 2024 12:47:33 +0000
When I do a replay. The price on my Dom is different than the price on the chart.
View Count: 164
[2024-05-27 16:09:39] |
User282886 - Posts: 23 |
Sorry to bother you guys. I tried to look and find the answer myself on your site first with no success. So therefore I'm having to reach out to you for your help. Sorry. Thank you ahead of time. When I do a replay. The price on my Dom is different than the price on the chart. It's the same market, same day, same month and everything else. So everything should be the same. But for some reason, the price on the Dom is way different than the price on the chart. I've checked my session times to make sure they were the same. Any help would be greatly appreciated. Thank you very much.
[2024-05-27 16:43:39] |
Sierra_Chart Engineering - Posts: 17154 |
You need to follow through the instructions here regarding this: Replaying Charts: Replaying Trade DOM Windows Make sure you have a sufficient number of days of data loaded in the Trading DOM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
